Body velcro option?
FL
Body velcro option?
I have seen where people are using velcro to secure the body to the car. This allows the driver NOT to have body posts sticking out of the body, and provides a more scale look.
How is this done and is there a tutorial on how to do this?
Also, how stable is the body on the car? I have a TC4.
URC
URC
ON, CANADA
RE: Body velcro option?
ORIGINAL: BIG BEAR
This is a rough idea but this is how I do it. ( I suck at explaining things ) The drawing should explain itself
Bend up some tin in a long c shape use some nuts to sandwich it to the existing body posts velcro on the tin velcro on the body and your done. no more posts sticking through the body.
ORIGINAL: Moo$e
how do you eliminate the body posts, coz i really wanna kill the body post things
Hope this helps
OK
Will it be harder to line up the body with velcro? I know a lot of my cars are pretty close regarding the space between the tire and the wheel well and any little shift might mean tire rub. Maybe not a problem for a drift car with smaller wheels/tires? Just curious.
how about using magnets?? hehe
Its not a viable option..
Velcro doesnt hold on too good when you have even minor impacts with walls and other cars..
I have seen drifters do this mod only to go back to poles...
This mod has worked alot better on my mini and will work on all of the 1/10 electrics. I'm not sure about TC's, I've never tried it on my old car. You should use the velcro on the chassis' sides, deff not the top.
