19T Vs 21 T
19T Vs 21 T
Hi guys,
I'm considering buying a 21T motor for my TT-01. With all the instabilities I heard running 19T on stock ESC, I figured 21T might be a safer bet. Do I get more torque with 21T? How about speed-wise? I'm also planning to upgrade to full ball bearings and an ali shaft.
RE: 19T Vs 21 T
how can be those motors in equivalent terms???...double vs. single wounded...I was thinking getting some 19Tx2 (double wounded) for my TT-01D, this shuld give a higer T-s than a 19Tx1...isn't it?...
I think 19Tx2 = 21Tx1...or even 23Tx1 [:-][:-][:-]
RE: 19T Vs 21 T
Pinion gear wise, what would be a good combo for max acceleration? The stock spur gear is 61T, should I simply keep the stock pinion or get a new one to suit the motor?
RE: 19T Vs 21 T
As for the amounts of winds on a motor you also have to consider the quality of the motor too ie i swopped a 21double vemon motor to a check piont money 19t and couldnt believe the difference in torque and power,it pays to buy the best motor you can afford
23/58 for drifting will lose too much torque even on rubber drift wheels its best to stick around standard gearing [8D]
RE: 19T Vs 21 T
Check out the checkpoint money with a tazer 15t esc.
I'm thinking about getting a brushless velineon setup so I wont have to worry about motor maintenance.
