batteries
batteries
i was looking at other posts and i saw one that said the batteries make or break the car. he is talking about the dura trax piranha 6 cell 1900mah. i was thinking of using that type of battery for my tt01d kit that i just bought since i already had them. i do not get what he means by break the car. hope to get a reply.
RE: batteries
Make Or Break = Weather you will enjoy the car or Not...
a 1900mah Battery is going to last around 7-8 minutes...
It is Recommended you buy a Battery that is rated at LEAST 3000mah in order to get a Decent run time out of your Car.
Drifting on a Smooth Surface with Home Made Polypipe tyres I can get at least 20 minutes Solid drifting from a 3000mah Intellect Battery..
It is also Recommended Getting a Delta Peak Charger that will peak your Batteries ensuring that they are properly Charged and looked after.
So A Charger that has an Amperage of 2 amps.. is going to take 1 Hour to charge Your 1900mah Battery..
Buying a Charger that has an Output of 3 - 5 amps will charge that same Battery in around 30 mins..
Make Sure that your Charger is nimh/nicd Safe..
Charging a Nicd Battery on a Nimh Charger is a Bad thing
Charging a Nimh Battery on a Nicd Charger is a Very Bad thing..
Make sure your Charger can do both..
If Your not sure what to Buy, Just post up links and we can assist you in deciding..
RE: batteries
EDIT that is on PVC wheels tho so traction is at Minimum maybe why...
MI
RE: batteries
well what he is saying is that decent 3000mah's will last longer than your batteries right now. Also if you need a peak charger, let me know because i have one id be willing to sell, its a duratrax intellipeak, the 54.95$ one.
RE: batteries
i have this charger is it good? its the piranha charger
http://www3.towerhobbies.com/cgi-bin...&I=LXCLD5&P=ML
what batteries would you recommend that are not too expensive??
RE: batteries
OK So your Charger is good...
http://www3.towerhobbies.com/cgi-bin...?&I=LXERB5&P=7 3000mah
http://www3.towerhobbies.com/cgi-bin...?&I=LXLFW4&P=7 3600mah (Intellect often under rate their Batteries so Expect around 3800mah)
http://www3.towerhobbies.com/cgi-bin...?&I=LXKWU9&P=7 2 of these would be OK..
Your not competitively Drifting so there is no need to go too overboard but the packs above would do nicely..
RE: batteries
thanks for the help. i did not really know what batteries to get but you narrowed down my choices thanks. what color do you think the subaru body would look cool in? i dont know if i want to paint it blue like the original or another color.
RE: batteries
I like Intellect 4200's... Often able to push 5100mah Into them and 1 4200mah Does my Practice runs AND my Comp run at meets..
Ooodles of power to spare aswell..
RE: batteries
i just bought the duratax digitial peak charger and myu intellect 3300 mah battery i hope its better then my 1 amp dynamite mega battery charger and my yokomo 1400 mah what you guys think lol
ME
RE: batteries
RE: batteries
omg i used my 3600 mah nihm battery with the perhana digital peak charger thats the best bang for your buck my one 3600 lasted for over an hour the battery is a intellect
