Different Tire Compounds???
CA
Can someone tell me what compound the Type-D is? Is it softer than the T-Drifts or SuperDrifts? I know the Sushi drift tires are the hardest. Thanks in Advance
Ric
Ric
RE: Different Tire Compounds???
there's basically different type of drift tires, high speed-soft rubber slicks, mid speed-pvc/rubber compound, low speed- pvc or molded plastic. all these tire compound are used for drifting, depending on the surface and the torque from your car-equipment, you drift or not.
i drift just i used the tires it came with not really sure what tires by what manufacter do different things to me i think its confusing
