My new Drift Body
CA
My new Drift Body
Just finished my Honda s2000 body 2day. This body will be going on my Himoto Nascada Street car What do you think??
The Body mounted on my Himoto Nascada
RE: My new Drift Body
looks pretty good overall on your decals try and cut off as much of the clear as you can and you should find another way to mount you side mirrors that white foam or whatever that might be takes away a lot of the realism mount those with some kind of glue what will adhere to lexan without damaging it and the two tone on your car looks pretty good but for the lines where the two paints meet looks like you masked that area in a rush take your time next time around but a suggestion for that is look for the blue painters tape that is only like a 5th of an inch wide it makes better curves but use that for the initial line you make for separating the two colors then fill in the main part with some wider tape until your happy with it and try and follow a body panel line for even straighter lines but i like your car you don't see many S 2000's good job
CA
1st Thanks for the GOOD Comments and i posted a few more pics on the 1st post.
Thanks for the advice. This is my 1st paint job with 2 colors. i have done a few Solid shell jobs. Ill try the blue painters tape next time. i might even try the Liquid mask. alot of my buddy's use that.
Thanks. i like it a lot.
Thanks.... the Shell is a
Specification:
Length : 440mm
Width : 215mm
Height : 113mm
Wheelbase : 257mm
ORIGINAL: leadfootdriver
ORIGINAL: billdozer1983
Looks great bud
Looks great bud
ORIGINAL: moflow
S2K's are tight. I'm not usually a fan of two tone, but black and blue looks pretty badass actually. What width is that shell?
Specification:
Length : 440mm
Width : 215mm
Height : 113mm
Wheelbase : 257mm
nice job on the body, but what did you use for your masking? was it something like painters tape or liquid mask?
CA
ORIGINAL: dvdeath3x
hate to be that guy but holy sh*t use some punctuation next time! [sm=biggrin.gif]
dvdeath3x hate to be that guy but use some punctuation next time!
Sorry for my bad puctuation I try and correct it but I usually don't have time I know how you feel though it bothers me to.
