RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
HPI Nitro Rush engine issuse!!!
Old 09-22-2010, 01:19 PM
Darius69
Default HPI Nitro Rush engine issuse!!!
Ihave an old HPInitro rush with an .OS engine on it. Ihas breaking the engine in and it was starting up really easy but blowing out a lot of fuel I popped the cooling head off and the piston ring popped out and I can't seem to get it back in any suggestions?
Old 09-22-2010, 01:56 PM
SyCo_VeNoM
SyCo_VeNoM's Avatar
Default RE: HPI Nitro Rush engine issuse!!!
your going to have to play with it. make sure its lined up and try and get the piston to center properly.
Also this is the electric forum you would do better asking in the Nitro, or general forum as you would get way more advice.
General Forum http://www.rcuniverse.com/forum/forumid_179/tt.htm
Nitro Stadium truck forum http://www.rcuniverse.com/forum/foru...smode_1/tt.htm
Old 09-22-2010, 02:49 PM
Slo-V Flyer
Slo-V Flyer's Avatar
I didn't think nitro engines even had piston rings. Are you sure that's what popped off? Or do you mean the gasket that goes between the cooling head and engine block/cylinder to seal the joint?
Old 09-22-2010, 03:10 PM
SyCo_VeNoM
SyCo_VeNoM's Avatar
My guess is the sleeve popped out. Which is what my advice was for it was the only thing I could think of that would seem like a piston ring
