RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
Is this ESC for heli/planes only?
Old 10-18-2010, 07:46 PM
xDIRTYSOUTHx
xDIRTYSOUTHx's Avatar
Default Is this ESC for heli/planes only?
WARNING! Noob Question:
Is this ESC for heli/planes only? Will it work for a car/truck/buggy setup?
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
Old 10-18-2010, 07:59 PM
genitor
Default RE: Is this ESC for heli/planes only?
Yes it is for planes.
If you use it for a car you will need to use mechanical brakes since it will not have brakes.
Old 10-18-2010, 08:02 PM
xDIRTYSOUTHx
ok thanks for the reply.
Slo-V Flyer
Slo-V Flyer's Avatar
And no reverse.
Might work for a nitro conversion, like one's with the reverse module that you can shift (T-Maxx, Revo).
Old 10-18-2010, 08:09 PM
SyCo_VeNoM
SyCo_VeNoM's Avatar
Probably will also get hot as hell seeing there is no heatsink to cool it off.
Old 10-18-2010, 09:21 PM
ThunderbirdJunkie
ThunderbirdJunkie's Avatar
No car ESC should get hot with or without a heat sink, TBH. ThunderbirdJunkie's Novak Cyclone speed control had an option of installing heat sinks, but he never did and that ESC never even got warm.
All in the gearing and setup fellers.
Old 10-18-2010, 09:22 PM
sheograth
Moderator
sheograth's Avatar
I beg to differ. You're right about most stuff but some of the powerful 1/8 ESCs will get cozy and it's totally normal.
Old 10-18-2010, 09:27 PM
Brainanator
Brainanator's Avatar
you guys read it?
* High rate PWM
* Low resistence
* User programmable brake
* Low voltage auto setting based on battery
* Throttle range self-adjusting
* Soft start ramp up
* Auto motor cutoff with reset
* Runs motor in forward or reverse
* Safe power arming program ensures motor will not run accidentally after turn on
* Low torque start
* Auto shut down when signal is lost
it apparently has brakes and reverse.
edit: and if you look at the picture is has a heat sink.... anyone else click the link but me?
Old 10-18-2010, 09:34 PM
xDIRTYSOUTHx
ORIGINAL: Brainanator
you guys read it?
* High rate PWM
* Low resistence
* Low torque start
Was thinking the same..It clearly has a heatsink and says reverse but it's listed as a Heli/Plane ESC..
Old 10-18-2010, 09:39 PM
Cleared2Engage
Cleared2Engage's Avatar
That's a prop brake. It works the same as the drag brake in castle esc's. It won't work like a cars brakes. Forward or reverse means that you can reverse the spinning direction of the prop without taking apart the cowl to reverse the wires.
Old 10-18-2010, 09:49 PM
Brainanator
good answers cleared2engage. [sm=thumbs_up.gif] didn't know that.
Old 10-18-2010, 09:57 PM
xDIRTYSOUTHx
So i guess this is not the kind of ESC i'm looking for. I was going to put this on a RC truck build along with Tacon BL 3200kv but guess i dont know enough about ESC's to know what i'm looking for..
Bummer..i already bought the damn thing..
Old 10-18-2010, 10:32 PM
Slo-V Flyer
Hah.. it's ok. just resell it for the same price.
As for car ESC, look for ZTW, or Aeolian, or ezrun. Those are about the only "cheap" car ESC you will find, ranging from $35-$75. I own a 60 amp ZTW, and it has been fine on 2s-3s on a 2700 Kv motor in my Slash.
Old 10-18-2010, 11:03 PM
Brainanator
test it out, and then re-sell it saying you tested it in america, and shipping is from america. You might even be able to make a profit, if not break even.
Old 10-30-2010, 06:05 AM
xDIRTYSOUTHx
I got the ESC in the other day and it's BIG. Looks nice though. The ESC doesnt have an ON/OFF switch on it like the stock one. What should i be looking for to turn the car on and off?
Old 10-30-2010, 07:27 AM
rc person 577
rc person 577's Avatar
Just by pluging in the the battery will turn it on and off.
Old 10-30-2010, 08:15 AM
xDIRTYSOUTHx
ORIGINAL: rc person 577
I figured that was an easy way to go about it. Was thinking there could be a switch added to the ESC somehow?
Old 10-30-2010, 09:29 AM
rc person 577
They make ones you can plug in between the rx and the esc. You could get a swithch on the red wire on the battery lead from the esc.
Old 10-30-2010, 08:32 PM
ThunderbirdJunkie
The switch on the stock ESC does nothing but cut power to the radio. If you leave a battery plugged in the ESC is still sucking power
Did you really think a pair of 24-28ga wires really cut battery power?
