If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 15 of 15
  1. #1
    Join Date
    Feb 2008
    Norwich, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Tires/setup for Indoor carpet short course racing
    Won my first ever race today with my 2WD Slash!!
    6 trucks: 2 SC10s, 3 Slashes, and a Losi Strike. Indoor carpet track, with homemade jumps.
    Had two qualifiers, and the main. In the two qualifiers, I placed 5th and 4th. Then I won the main!
    In the first two races, I had trouble keeping it right side up, kept rolling on me. I know, the Slash has a high center of gravity.
    It was running great for the first 5 or 6 laps. But it seemed like as soon as the tires got warm it would flip at every turn.
    I tried stiffening the suspension, by preloading the springs with spacers. That made it worse. Then I went way soft by taking all of the spacers out. This helped the rollovers, but the problem though was I bottomed out on every jump.
    So, I need a happy medium. I know if I make the suspension stiff enough to not bottom out, it's going to flip. So what tire do you guys use on carpet? I need something that'll have some lateral slide, with enough traction that I'll won't just spin the tires when I squeeze the throttle (if that even exists).
    www.rcsoup.com - R/C Reviews, News, and Tips
  2. #2
    FoamyVictim's Avatar
    Join Date
    Sep 2005
    Ft. Walton Beach, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Tires/setup for Indoor carpet short course racing
    Find slicks or a very hard compound. Maybe something like these:
    http://www.amainhobbies.com/product_...-Truck-Tires-2
  3. #3
    Brainanator's Avatar
    Join Date
    Jun 2009
    Great Falls, MT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    you can also try dropping the clips out, but then putting much thicker weight oil in the shocks. I'd suggest around 60 weight (30 is stock)
    OFNA Jammin CRT.5e, stock sprint 2 drift, Savage Flux (4S), slash (just a roller for now)
  4. #4
    ThunderbirdJunkie's Avatar
    Join Date
    Jul 2004
    Norwood, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Have you considered just doing a Rustler chassis conversion and stretching it with something like the STRC LCG kit?
    \"Some people can mess up an anvil with a rubber hammer\" -46u
    If you don\'\'t allow yourself to fail, you\'\'ll never allow yourself to succeed-ThunderbirdJunkie
  5. #5
    Join Date
    Feb 2008
    Norwich, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i did pull the clips out, which seemed to help. But it was too much, because I kept bottoming out on the jumps.
    How about shock position? Any benefits to moving them to a different hole?
  6. #6
    Join Date
    Nov 2008
    ann arbor, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I found a lot of drivers are using http://prolineracing.com/tires/strik...t-truck-tires/
    works really well for indoor carpet
  7. #7
    plasmaedge's Avatar
    Join Date
    Sep 2009
    Auckland, NEW ZEALAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Tyres -     http://prolineracing.com/tires/suburbs-sc-2.2/3.0-m4-super-soft-tires/
    Shocks - low down
    Oil - 55wt/60wt
    should get you going prety good.
    Team associated t4.1 (currently a roller)
  8. #8
    Join Date
    Jun 2009
    Great Falls, MT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: godofcable
    right, but you didn't change the shock oil to something heavier (about 60 weight is good). The heavier oil will keep you from bottoming out better. and it's not like bottoming out is the worst thing ever, flipping over is far worse.
  9. #9
    Join Date
    Feb 2008
    Norwich, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    what do you mean by shocks - low down
  10. #10
    Join Date
    Feb 2008
    Norwich, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Brainanator
    agreed that flipping is much worse. The problem with me bottoming out was the rear tires would jump off the ground when i bottomed out, and for about 4-5 feet i had no control.
  11. #11
    Join Date
    Jul 2004
    Norwood, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: plasmaedge
    Tyres - * * http://prolineracing.com/tires/suburbs-sc-2.2/3.0-m4-super-soft-tires/
    Shocks - low down
    Oil - 55wt/60wt
    Since there's really no lack of traction on carpet, M2 Suburbs would be better. The harder compound would give you a stiffer sidewall and help prevent traction rolling.
  12. #12
    plasmaedge's Avatar
    Join Date
    Sep 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    true, and better tyre life.
  13. #13
    BuzzBomber's Avatar
    Join Date
    Dec 2002
    Newton, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    AT my club's track, we only run stock brushed slashes with stock tires on our carpet track, but here's how we cope with traction rolling(yes, this is allowed under our rules): tape the front tires. One wrap of electrical tape around the outside edge of the front tires takes away just enough traction to keep the truck from rolling in every corner without pushing/plowing too badly. You have to experiment with how far inboard you place the tape for best results. FWIW, I run no spacers on the front, and one thick spacer in the back, with 40-50 weight oil. I'd rather have chassis slap than traction rolling......YMMV, since your tracks rules are different.
    Matt Smith
    If you\'\'re not having fun, you\'\'re missing the point.
  14. #14
    Join Date
    Feb 2008
    Norwich, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    we are still experimenting with the class. right now they are saying its "open", meaning run whatchya brung, but this was also knowing that all entrants were using brushed motors. if guys start showing up with brushless trucks they may change things.
    i ordered the shock oil, should be here any day. someone had mentioned having the shocks "low down" . . . can someone clarify that?
  15. #15
    plasmaedge's Avatar
    Join Date
    Sep 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    hey, what i mean by low down is have the truck sitting lower down than you would for bashing, effectievly lowering the COG and helping with racing.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
