gearing for a Slash brushless conversion
NY
i've searched the forums, and haven't come up with what I need.
I'm going to do a Slash brushless conversion. However, I need input on gearing. I want performance without the heat issues from overgearing.
Would love to keep the stock spur gear, in case I want to put the stock motor back in and run the spec class.
OH
RE: gearing for a Slash brushless conversion
ORIGINAL: CarGuy7a
More info is needed on what ESC and motor kv you plan on running before we can start talking about gearing.
ORIGINAL: Brainanator
very highly depends on the brushless combo you have.... 22/86 would fry a castle 4600 motor very quickly in a slash.
Now the 4600 probably wouldn't fry at 22/86, because ThunderbirdJunkie has run 22/87 in his SC10 with that motor, and the transmission ratio is taller than that of a Slash.
NY
also thinking about picking up the optional cooling fan that mounts to the top of the ESC.
Anyone know what size shaft on the VXL 3500 motor? 5mm?
MT
ORIGINAL: ThunderbirdJunkie
Good call guys...didn't even think about that. Was just jumping to the Velineon 3500 conclusion.
OH
Really? on the track, ThunderbirdJunkie runs 20/87 in his SC10, and has run up to 24/84 with the hottest recorded temperature while bashing being 160.
ORIGINAL: godofcable
You're right.
A Velineon 3500 with matching ESC fell into my lap, it came out of a brand new Slash 4x4.
You're right.
VA
i run a 16/90 on 3s with a 4420kv motor thats onroad but when i bash on 2s i like 18/86 stays cool motor and esc but thats with a cc sidewinder esc
NJ
I tried some pretty "cool" gearing like 18/90 and still ran into heat issues so I got an aluminum tranny case and was done with it, works like a charm. I tore the whole truck apart trying to find binding but everything was smooth, I guess it was my driving style lol, but the tranny case has helped drastically.
