Hyper 10 sc w/mmpro sys.???
Howdy all, I'm new to the brusless side of the hobby and got a good deal [:-] off the bay.... this came with a venom 14.8 lipo 5000mh which was NOT ran with the mmpro sc system, i checked with the manual and it reads that it can be set-up to run with it, any recommendations so's as not to cook the system, for regular track practice i"ll be using a 7.4 2c 40,5000mh, but because it came in the deal,could it be used safely, any recommendations/comments are appreciated...Thanks all.......... Mopartybob
SK, BANGLADESH
RE: Hyper 10 sc w/mmpro sys.???
what motor is that? the picture is hard to tell, but it looks like a smooth can, not the ridged can the SCT motors have
looks like a MMP with one of their CM36 motors
you are correct,it is Not the ridged can (my bad)... I have yet to recieve it so I'm not sure what size the motor is...... will update asap... MPB
recieved it today,turns out to be a Mamba Max Pro Electronic Speed Control, 5700kV motor, I checked the specs and it will accept up to 6s...... now to figger out the gearing......went to the castle website checked the specs on the gearing,...shows it is NOT recommended (motor) for 4wheel drive....***???? mpb
SK, BANGLADESH
the 5700 motor can only accept up to 3s, and with the weight of a 4wd short course truck I think you'll find that motor overheats no matter what you do
it's just too heavy of a truck to run on that motor
you could buy one of the tekin or novak 550 can sensored motors, or if you want to be slick with things....
buy the castle sidewinder SCT system, for about $100... you can use the sidewinder ESC with your 5700 motor in a lighter RC and use the SCT 3800KV motor with your MMP esc in the 4wd
then you've got 2 brushless setups!
AZ
sidewinder sct wont handle 4s lipo ether
ORIGINAL: mopartybob
thanks sloppyg, I'll go with the castle sidewinder SCT system ......i'd rather be slick than slack ... mpb
SK, BANGLADESH
ORIGINAL: Krazy Chicken
he can use the MMP with SCT 3800kv motor on 3S (that motor is rated at 100,000 rpm max)
and the sidewinder with 5700kv motor on 3s
both will be stupidly fast, and even on 2s both systems will have a ton of power
CA
you already have a nice ESC. no need to go out and buy another system. if you plan to race only, i'd say to go get a novak 550 in 4.5 turns. that will only allow you to run 2S lipos. if you want to run that 3s, get the 5.5T novak.
4.5T Novak: http://www3.towerhobbies.com/cgi-bin...&I=LXZUJ4&P=SM
5.5T Novak: http://www3.towerhobbies.com/cgi-bin...&I=LXZUJ5&P=SM
the 550 can motors use a 5mm shaft so you would have to buy some 5mm pinions...
SK, BANGLADESH
ORIGINAL: RC*PHREAK
while I certainly agree those novak motors are nice, they are the same cost as the sidewinder SCT combo, so for the same money he can have one brushless system, or two systems
the 5mm motor shaft is nice on the novak, (give you more pinion options as it's pretty hard to find 3mm mod1 pinions, although ofna does make them)
word so far is that the 1410 motor in the SCT combo is equal in power to the novak motors
the novak (or tekin) are sensored, which would make them smoother
plenty of good reasons to make either choice, the 550 cans are nice for racing, and it's also nice to have a second brushless setup around for your next project
Great info guyz,Thanks,this will be used mainly for racing on 2s lipos,as i will have/have other applications for that battery power, I'll be going with the 5.5 novak,as i already have a deal goin on with the the other motor...... once again,THANKS MPB
By the way,I'll be running on a short outdoor technical track, can someone esplain the gearing options/differences for the 4.5 motor ??? Thanks
CA
i have recently purchased two sidewinder SCT's and one of the 1410 motors. IMO, so far the sidewinder sct esc's are not good. they both run very hot. i haven't had much time to mess with them, but here are the set ups i have run them on:
truck 1: SC10 with velineon motor and 23/87 gearing. after about a half of a 5000 2s lipo pack, the motor was about 150 and the esc was 160.
truck 2: slash 4x4 with 1410 motor and 15/54 gearing. all i heard about was how much torque the 1410 made and how cool it ran so you could gear up. i went up only 2 teeth from stock. after literally 5 minutes of basically just speed runs up and down the street, the motor was already over 150 and the esc was at 170. yes, it was pretty damn fast. in the system's defense, my gear mesh might be tight so i will double check that before i run it again.
hopefully i will be able to get some track time tomorrow for more testing.
i have also read several other accounts on various message boards about the sidewinder sct esc running hot. especially in slash 4x4's. i just don't think it works well in a 4x4. i just wouldn't feel right recommending that this guy go out and spend $120 to put an esc in his truck that isn't as good as the one he has. he has a very nice esc, why not mate it with a good motor? to me that would be more important than a possible second vehicle.
CA
there's where i go (it's actually union city, but real close to hayward). i'm pretty sure most of the guys running in the 4x4 SC are using the 4.5T 550's. either tekin or novak. if you're not concerned about running that 3 cell lipo, i would get the 4.5T novak.
Too Late........ , I went with the novak 6.5 turn motor, I also ordered the extra pinions 12t-17t, i'll be usin that 4s 5000 lipo and play with the gearing as needed, for whether i'm playing or racing, I went with the 6.5 just to help expand my learning curve into the brushless world,as i now know that 4.5, 5.5, motors are the recommended set-up, will keep y'all posted as to hows go's, but thanks all for the info... mpb
YOu might regret the novak. i smoked two of then now i am a Castle runner through and through. Here is my Sc10 2.0 with the Castle SCT set up. Running 15 tooth pinion on 3s. Way to much actually.. The ESC runs in the 100 degree range and the motor is 125 degrees after completey depleting a 5000 mah 50c 3s lipo.
YIKES......... [X(] that makes two of youz that have smoked novaks..... !@%$@#!@# let me call my LHS and see wassup THANKS MPB
Thanks, any info/reviews on the Tekin Redline SC4X Sensored Brushless 550 Motor (4.5T) I've read that this is a 2 pole motor,but with a longer can,how does this compare with a 4 pole motor???? please excuse newbee type ???
CA
the people that have them seem to like them. should be pretty comparable to the novak 550 4.5T. again, this motor is 2s only. should give you everything you need for the 1/10th scale track though. just can't bash it with 3s or higher...
