New HobbyKing "B Grade" Lipos
NJ
So I received an email from hobbyking that they are offering new "B Grade" LiPos which seem to be incredibly cheap. Now, maybe it's just me, but these seem to look exactly like the Hobbypartz blue lipos. The specs of them are also written in the same format which makes me think they are the same.
http://www.hobbyking.com/hobbyking/s...idCategory=431
RE: New HobbyKing
ORIGINAL: Dale Gribble
Man, I guess at least they are being honest, but the write up on them sure doesn't give you a warm and fuzzy feeling does it?
FL
RE: New HobbyKing
That description is brutally honest lol. Their A grade stuff is cheap enough for me and they work...I would rather spend a couple extra dollars on those.
RE: New HobbyKing
"B-Grade Lithium Polymer packs are great for those not-so-important models or testing. They have a high internal resistance (thats bad), normally wont last past 60 full high-discharge cycles and may become puffy over time."
love how they state they say hextronic sells B-grades which is what hobbypartz is billed as on credit card statements
Basically I'm guessing some of those packs are higher capacity packs which didn't meet the minimum reqs, and were down marked.
But if you charge em slower, and use them in low current draws they will preform fine
Hell I use the 3S 15C 1800mah blue lipos in my radios seeing current draw is a minimum. A $13 pack that lasts 2X longer than a set of AA's per charge in my book is a good investment even if it gets only 60-100 charges.
RE: New HobbyKing
ORIGINAL: rc awesome
Yeah it seems like a bargain deal though wonder what the preformance would be when compared to a decent nimh?
RE: New HobbyKing
ORIGINAL: SyCo_VeNoM
IMO as long as you don't over do it they should out preform NiMh's. Lets face it they got a 5000mah 4C lipo for $15 where I'm guessing a comparable NiMh pack from other places is around $50-60 (ok I know a place that does that for $20 but they get HOT). So if you pair that up with a 1/10th scale 60A ESC it should blow away almost and NiMh for performance, and run times. It also shouldn't tax the packs too much so they should last awhile.
Yeah it seems like abargain deal though wonder what thepreformance would be when compared to a decent nimh?
