Problems with ESC
MI
Problems with ESC
So my 3 week old Castle Sidewinder v2 is acting up...anyone know which Hobby Wing ESC would be a good match for the Castle CM36 4600kV motor?
After some laps at the track today it started cogging really bad and it only runs at about 3/4 power it seems now...I've tried switching everything and can't find anything wrong other than the ESC...it was running perfect last night though.
MI
RE: Problems with ESC
I wish that's all it was I'm already on the latest Firmware.
It was a weird day... originally I thought it was my TX because I noticed the antenna had a nick in it that went 1/4 of the way through it...so I came home and put my old AM setup in it and it still didn't appear to fix it.
I think the TX was causing most of the stuttering issues, but even with the different TX/RX it seems it's not running full power. Last night if I were to say just punch it, it would flip right over on it's lid, now if I punch it, it barely lifts the front wheels off the ground.
AZ
what are you using for batteries? and just call castle, they have good support. no need to spend money if you dont need to
ORIGINAL: Teknic
It was a weird day...originally I thought it was my TX because I noticed the antenna had a nick in it that went 1/4 of the way through it...so I came home and put my old AM setup in it and it still didn't appear to fix it.
MI
I'm using 2S Lipo's, I tried multiple batteries and same results.
ORIGINAL: Krazy Chicken
ORIGINAL: Teknic
MI
Well I just got home and threw a battery in it and it seems like it has it's top speed back, but it's definitely not as torquey as it used to be...
SK, BANGLADESH
I'd suggest talking to the people who can help you CASTLE
instead of talking to us idiots, part of the reason you buy CASTLE stuff is that if there's an issue you can call them since they're in the USA
SK, BANGLADESH
Ok, but seriously
first cut the switch off and solder the wires together, then buy a castle BEC and install that on your system
also switch the red and white motor wires, then you should be back in action
TX
Can you interpert what you just said as it does not compute in my gammer in which was taught as a kid and teen.....
ORIGINAL: ThunderbirdJunkie
YO DAWG YOU SHOULD DEFINITELY CALL AIRTRONICS ON THIS ONE THEY'LL FIX YO SPEED CONTROL FO YO DAWG
SK, BANGLADESH
ORIGINAL: res3567
MI
ORIGINAL: burnineyes
Did you re-calibrate your endpoints after switching radios?
I hooked a battery up to it last night and noticed the speaker in the ESC is beeping again, but it's very quiet compared to how it used to be. It seems like it has it's "top end" back, but it's very low on torque now.
I emailed Castle support yesterday and am awaiting a response.
Back to my original question. If Castle doesn't replace my ESC what HobbyWing ESC would I need for my CM36 4600kV motor the 35A or 60A?
OH
There is no speaker in the ESC. This is not a speed control issue, the rotor in your motor has demagged.
The ESC vibrates the motor to make noise. If there is no motor hooked to the speedo, then there is no BEEDLEDEBOOP BEEP BEEP.
FL
ORIGINAL: Teknic
Yeah I recalibrated, I've actually since tried putting the Castle combo in my Fiesta with similar results.
I hooked a battery up to it last night and noticed the speaker in the ESC is beeping again, but it's very quiet compared to how it used to be. It seems like it has it's ''top end'' back, but it's very low on torque now.
MI
MI
+1 TBJ, no speaker, its the motor beeping. From the info I have I cant say with a ton of confidence that your motor is de-magged, but it would certainly make sense at this point. I would also recommend checking all of your connections very closely. The 60A EZRun would be perfect for the 4600kv motor, but you will want to ensure that is what you need, as it seems like it may be a motor or other issue. Email is fine, but to get the best possible service I would suggest to call Castle and speak to someone while you have the car, with a fully charged pack, in your hands ready to test.
ORIGINAL: Teknic
So you think it may be the motor? I've tried unplugging and replugging in the wires connecting the motor to ESC and they still have a very firm connection.
I actually ran the truck today at the local track again and it seemed to run decent, but like I said it's like it has 10-20% reduced power and doesn't have the punch it used to. I also noticed today that it seems like it has a hard time going into reverse (it stutters/pauses really bad when I try to reverse).
The rotor of the motor is demagnetised. You need a new motor. Your motor is a speaker, so the noise will be quieter when the magnet gets weaker.
MI
Sweet...well maybe Castle will fix it...I always check temps, granted I don't have a gun, but it's never gotten any hotter than I could put my finger to it for at least 5-6 seconds.
I'm thinking I may order a Tacon motor just to have as a backup either way since they're pretty cheap. Any suggestions on a motor that would work well in my Rustler with my Sidewinder v2 ESC? It would be a bonus if it's something that would work in the Slash 4x4 I have coming as a backup also.
