Rim hub
VA
Rim hub
So i was having problems with my wheel and i found out that the problem is my friend put industral strength lock tight on the wheel i got the wheel off by just seer luck and pulling. But the rim hub is still stuck and i cant get it off any suggestions what to do ( car is an earthquake 8E)
IL
RE: Rim hub
ORIGINAL: raceingnub25
RE: Rim hub
Most wheel hubs -or wheel axles- has a cross pin running through them, on which the hub is snapped on to. Try to pry it off with a flat bladed screwdriver supporting it on the edge of the bearing holder (or steering knuckle).
VA
RE: Rim hub
Im not quite sure it was grey in the bottle and was very liquid like and was labled industrail strength like i said i didint put it on so i dont know much about it
OH
RE: Rim hub
If it's got 8mm 1/8 scale style axles there is a 4mm grub screw that goes into the end of the axle to secure the pin. You should be able to use a 2mm driver to get that out. It's best to put the wheel on the hex so you have something to hold the axle still while you're cranking on it.
