If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 13 of 13
  1. #1
    Join Date
    May 2010
    , NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    REPEATEDLY STRIPPING SPUR GEAR HELP!
    hello all, need some quick suggestions for my redcat volcano epx brushless pro. i had previously replaced the spur with the new steel replacement since i kept stripping the plastic ones with the lipo battery. The issue is, i cant drive the truck more than a few minutes b4 it strips loose from the pinion. Both are steel, but somehow, they just separate. Imeshed them properly and tightened the bolts b4 using it, but it happens nonetheless. any suggestions out there??????
  2. #2
    xerxes's Avatar
    Join Date
    May 2011
    cicero, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: REPEATEDLY STRIPPING SPUR GEAR HELP!
    so da 2 steel 1s arnt strippn, der un-meshing?
    try a dab of blu loktite or thik ca glue on each screw b4 u tightn it.
  3. #3
    cumquat's Avatar
    Join Date
    Mar 2008
    kalamazoo, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    you should look for the reason the plastic spurs where striping. gears shouldnt strip very often, only when they are worn out. my guess is there is some binding in the drive-line, possibly a pin that is coming out. as for the motor moving, check all screws to see if they are tight and if it still comes loose, do as xerxes said, blue loctite on the motor mount screws.
    HELP! IM STUCK ON AN ESCALATOR!
  4. #4
    Link119's Avatar
    Join Date
    Aug 2010
    Exton, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: xerxes
    So the tow steel ones arent stripping, they are unmeshing?
    Try a dab of blue locktite or thick ca glue on each screw before you tighten it.
    Or get new motor screws if the current ones are stripped.
    And you dont want ca glue on your screws. That would destroy the point of screws and they would become rivets.
    I Ca glued a heatsink over my existing esc heatsink and the overheatsink just wont come off. Its like welded.
    Gws Slow Stick Brushless
  5. #5
    xerxes's Avatar
    Join Date
    May 2011
    cicero, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Link119
    And you dont want ca glue on your screws. That would destroy the point of screws and they would become rivets.*
  6. #6
    Haddi Taha's Avatar
    Join Date
    Feb 2010
    Sydney, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Follow these rules:
    use a good screw driver set for setting the screws
    replace worn screws ASAP
    always try to use steel hex headed screws where possible
    don't use the crappy L shaped wrenches included
    push down on the screw with the driver to stop the screw head from stripping and this enables maximum tightening
    purchase appropriate threadlock and use on the screws
    replace any worn gears asap
    always get high quality gears
    make sure you use gears of the same pitch (people do make this mistake)
    Also, the pinion screws on the redcats are crap, get some higher quality ones from another brand
    Thunder Tiger MT4 G3- Tamiya TA06 Pro
  7. #7
    cumquat's Avatar
    Join Date
    Mar 2008
    kalamazoo, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    robinson racing makes some of the best hears and set screws out there and have been for upward 30 years.
  8. #8
    hindupimp2384's Avatar
    Join Date
    Jan 2011
    Rolla, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    yea i was stripping my spur too and found out i was using the 0.5 pitch Pinion gear instead of 48 ptich
    - CUSTOMIZED RUSTLER SV2 1406 Neu-Castle 4Pole 5700KV
    - RUSTLER SV2 2 Pole 5700KV
  9. #9
    Haddi Taha's Avatar
    Join Date
    Feb 2010
    Sydney, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: hindupimp2384
    its happened to nearly every rc hobbyist at one stage. When I was a noob, I thought my tt01e had 48pitch (because they looked the same, bought some and stripped 3 spur gears in a row (they costed $2 each) Then I realised that 0.6 pitch existed so I bought some Yeah Racing hard coated 0.6 gears, problem solved
  10. #10
    Join Date
    May 2010
    , NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    thanks for the help, i think i'll be starting with the screws, the gears are rather new and i had already upgraded from the plastic spur gear that was getting chewed up constantly. Probalby a dumb question, but the screws you guys are referring to are the ones that old the pinion gear onto the motor and the screws that hold the spur gear down right?
  11. #11
    cumquat's Avatar
    Join Date
    Mar 2008
    kalamazoo, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    no, the screws that hold the motor. yes to the pinion set screw.
  12. #12
    The Mad Modder's Avatar
    Join Date
    Oct 2006
    eastern, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: cumquat
    robinson racing makes some of the best gears and set screws out there and have been for upward 30 years.
    +1 I love their pinion gears. They're very high quality.
    God bless America
  13. #13
    Join Date
    Apr 2009
    South East, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: xerxes
    Yeah, CA on a steel screw into aluminum... nice suggestion donkey.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
