Help choosing battery & charger (savage 2350)
Been in the hobby quite a while exclusively in the nitro portion, looking to learn and play around with the Electric end of it now.
I recently read this article
http://www.rchelicopterfun.com/rc-lipo-batteries.html
Now i need help choosing battery packs and a charger, and connectors
Car? Savage 2350
I will be running 2 2s in series (is this battery a good option)
http://www.hobbyking.com/hobbycity/s...dProduct=11938
along with this charger?
http://www.hobbyking.com/hobbyking/s...idProduct=7028
http://www.hobbyking.com/hobbycity/s..._GENUINE_.html
OR
http://www.hobbypartz.com/73p-ac680-accharger.html
Would this work for my application? Since the charger is relatively cheap should, should i buy 2 to charge both batteries at the same time, or can i run them in series and get only one charger?
These look like ec3 connectors, do i need to purchase different connectors to hook up to the savage?
any more info would be appreciated as i want to order all at once, i do have a soldering station already.
THANKS IN ADVANCED!!!
Car? Savage 2350
OR
RE: Help choosing battery & charger (savage 2350)
bad URL's
you need the full thing the URL's you posted were shortened probably in your browser address tab with ...'s
ORIGINAL: SyCo_VeNoM
bad URL's
bad URL's
also feel free to post a entire different setup, have up to 200 to spend, but wouldn't mind spending less!
Good choices for batteries and charger. Might be worth spending the extra to get a charger that can charge two batts at once, since you'll be using them in pairs.
OH
50c burst on a 6000 on a truck that can spike over 300a is kind of ehhhhh, but, you're at a good starting point.
When you first start running the truck, keep an eye on battery and motor temps.
I don't think the 2350 ever gets up to 300A [X(]
I use a pair of 5000mAh 20c for pissing around and they get warm, but never anything even resembling hot. My 30-60C don't get warm at all tho.
ORIGINAL: Foxy
Back on topic if you go with the accucell 6 chargers I'd get 2 and make http://www.rc-monster.com/forum/showthread.php?t=27554 to power them
I've tried the 2 power supplies made for chargers that were rated to allow me to run 2 chargers simotaneouly off them, and toasted both of them running only 1 charger not even at full power. That server power supply on the other hand has survived me running 3 chargers at once at full blast, and can still take more I estimate 6 chargers at least could run at once off it
The battery never tried the nanos, but heard god things about them
http://www.hobbyking.com/hobbyking/s...ischarger.html
And charge in parallel. And get a nice pc power supply and do this...
http://www.wikihow.com/Convert-a-Com...b-Power-Supply
But also put the 3.3 wires because those are good for breaking in motors...
ORIGINAL: Link119
Now as a lab power supply the pc power supply is great
I use this power supply http://www.amainhobbies.com/product_...r-Supply-Black
And a dual charger, and I charge 2x2S 5000mAh packs at 10A each simultaneously. Makes charging for the flux a breeze, 6 packs ready in about 100 minutes (less than 80 if I don't balance). I've only got a couple of cycles on this charger, I'll do a write up of it in a few days, but so far it's been outstanding mated to that power supply. REally happy with these 2 purchases.
http://www.amainhobbies.com/product_...S-10A-200W-x-2
ORIGINAL: Link119
So my battery choice is ok, this charger seems good. I have at least 20 PC power supplies so i think i will make my own.
What is the connector coming out of the savage 2350 ECU, is it deans?
Do i need to order deans connectors for these batteries?
Thanks again!
Yeh, 2350's MMP is deans equipped and comes with a deans serial connector too (for 2x2S batt). Depending which batteries you buy, you may need to solder female deans to the battery, yeh.
PS. I also have at least 20 PC power supplies, yet I still shelled out $140 bucks for a nice strong purpose built one. Think about it if you have the money
ORIGINAL: Foxy
So would this be the proper deans connecter
http://www.hobbyking.com/hobbycity/s...dProduct=10765
And as far as the charger/power supply goes, is there a combination that can charge both my batteries in parallel for less than 100?
also if i use this charger
would this power supply (choose this bc i have an amazon credit)
http://www.amazon.com/Corsair-Enthus...1183457&sr=8-6
ORIGINAL: dmx434343
1) i will be using this battery
2) So would this be the proper deans connecter
3) And as far as the charger/power supply goes, is there a combination that can charge both my batteries in parallel for less than 100?
ORIGINAL: Foxy
2) Those deans connectors seem very expensive, can't you get those at your LHS?
3) Maybe, checking your links below...
K, charger and that PSU would surely do it, but more than $100, still, decent combo if you get that board that allows you to charge them in parallel with it, which I think you do.
MO
OKEY
Listen i know that all these chargers are cheap. But remember cheap electronics dont last, short or have no warranty. I just dont trust Chinese products that are made with cheap and cloned parts. i promise these products have a huge risk are electric fires or shorts. Now for the charger i would go with...Passport Ultra...look at this
LINK yes its $130 but its worth it. It comes with everything you need balances, has AC and DC power included, charges all batteries, has temp gauge, its does alot.
BUT AS FOR BATTERIES ... Hobbykings... Trinigy is are excellent batteries you want to choose USA warehouse then you pick your battery get over 25c and a soft pack, as the hard packs shatters upon jumps.
ORIGINAL: hindupimp2384
OKEY
OKEY
http://www.amazon.com/TP610C-ACDC-Ce...ref=pd_sbs_t_1
Its 10a so it can charge my batteries in parallel a bit faster correct? And its from amazon so i can use my gift card i have!
So that along with the turnigy nano techs and im on a roll?
ORIGINAL: Foxy
1) Battery seems good.
ORIGINAL: dmx434343
ORIGINAL: Foxy
my LHS isnt so Local, was trnya get the deans online. Should i buy the deans that don't include the extra wiring like these.
http://www.amazon.com/W-S-Deans-Comp.../ref=pd_sim__1
im having a hard time figuring out which batteries come out of the USA warehouse on hobbyking.. when i click "USA" it doesn't actually give me the usa items. anyone know which battery is similar coming out the usa warehouse
figured it out,
the nano techs are international warehouse which sounds like a pain.
Which of these two batteries..?
http://www.hobbyking.com/hobbyking/s...arehouse_.html
2nd one is a bit larger which is my only concern, otherwise its 40c vs 30c.
