If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 10 of 10
  1. #1
    Join Date
    Feb 2005
    Philly, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Battery in the center or on the side?
    Hello,
    I wanted some advice on my brother and I getting 2 trucks
    Is there a real difference in jumping and cornering with the battery in the center or on the side?
    A few things we want in the trucks : 1) 4 X 4, 2) Brushless, 3) water proof, 4) good upgrade support (metal parts)
    We don't want to spend over $300 to $400 each to get started and would like something that is RTR
    I have been reading about so many brands I don't know where to get started
    I spent some time reading about the Traxxas Slash and the E-Revo
    We are trying to decide between 1/10 and 1/16
    Joe
  2. #2
    Join Date
    Apr 2004
    PDX, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Battery in the center or on the side?
    The 4wd Slash sounds like the truck you are looking for.
    Or take a look at the Savage XS, it is a 4wd mini that is larger than the Traxxas mini's.
  3. #3
    proanti1's Avatar
    Join Date
    Dec 2004
    Boerne, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Traxxas would be your best bet... but NO RC car is truly waterproof. Water can still get into the bearings and transmission, the motor is also not "waterproof" as Traxxas claims. 1/10 scale stuff can handle grass a bit better than the 1/16th scale stuff.
    Her name was Lola. She was a show girl.
  4. #4
    Join Date
    Nov 2008
    Clifton Heights, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi [8D], The Traxxas Slash [>:] 4X4 RC Truck Would Be You & Your Brothers Best Bet... His Will Be Faster.... hahaha [:-]
  5. #5
    Join Date
    Aug 2006
    Mantua, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    With a 4x4 the location of the battery is usually offset to one side and then the motor and ESC on the other so its not like its totally off-balance.
    Mad Force Kruiser VE/ MM E-Revo / 2x 2wd Slash / 2x 2wd Stampede / Slash 4x4 / Vaterra BL Camaro / Axial SCX10
  6. #6
    Join Date
    Feb 2005
    Philly, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The Slash 4X4 Brushless RTR sounds nice
    After proanti1 mentioned 1/10 scale can handle grass a bit better I think we definitely want to go the 1/10 scale (thanks)
    For the extra cash is the slash worth getting in the "Ultimate" for the upgraded parts? or the Platinum getting my own radio?
    Blue-anodized 6061-T6 aluminum C-Hubs
    Blue-anodized 6061-T6 aluminum steering blocks
    Blue-anodized 6061-T6 aluminum rear hub carriers
    Blue-anodized 6061-T6 aluminum axle nuts
    Hard-anodized, Teflon-coated Big Boreโ„ข shocks with Titanium Nitride shafts
    Adjustable front and rear swaybars
    Included optional extra-stiff swaybar set
    Sealed, silicone filled center differential (included separately)
    (installs trackside in just minutes replacing the Torque-Controlยฎ slipper)
    Officially-licensed BFGoodrichยฎ Mud-Terrainโ„ข T/Aยฎ Tires molded in S1 race compound
    Hey deviltrigger, so if the battery is on the side these trucks don't roll in that direction when you jump?
    Hey mike, you forgot, MINE will be faster since I will secretly upgrade before you..
    Thanks Guys
    Joe
  7. #7
    Join Date
    Feb 2005
    Philly, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I forgot one thing, What 3 cell battery do you guys use?
    I am into Planes and buy Good Cheap batteries from HobbyKing, anyone using them?
    The 25 C spec is easy to find cheap at HobbyKing
    (they even have 35 c for very cheap and they last a long time, I have some that are over 2 years old)
    Thanks Again!
    Joe
  8. #8
    Scottgir's Avatar
    Join Date
    Jun 2007
    Manchester, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Dont forget the 4X4 Stampede. It's everything you're looking for and a bit more ground clearance than the slash.
  9. #9
    Join Date
    Aug 2006
    Mantua, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Lots of people on here love hobbyking so yes keep on getting whatever 3s 20c+ lipo you can get from them.
    Like scott said, the 4x4 stampede is another option but don't get it for the reasons he stated. Get the slash 4x4 and you get the longer wheelbase and less cramped chassis, and if you want more ground clearance throw on bigger tires and an MT body and you're set. I personally see no reason for a stampede 4x4.
    I do recommend either the ultimate or platinum because it comes with the aluminum parts that are where you want aluminum, and where common breaks are for the plastic. You would most likely replace those with aluminum at some point and it will cost you more down the road.
    Also no, I do not notice my slash 4x4 to be prone to rolling in any certain way because of weight, the motor and batteries usually offset themselves.
  10. #10
    Join Date
    Feb 2005
    Philly, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi deviltrigger,
    We are going to order 2 of the Slash 4X4 ultimate today, We found them for $450 each (delivered)
    Thanks for your input on the batteries and larger tires
    Longer wheelbase and larger tires sounds like a winner to me
    Thanks Everyone!
    Joe
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
