RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
Battery and gearing
Reply
Old 12-10-2011, 01:04 PM
rsking45
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Battery and gearing
HI all,
I bought my son a used exceed 1/10 truck. The Manuel says to use 7.2v 1800-3600 mAh ni-mh batery... when running the 1800 battery the esc gets a little warm towards the end of the charge.. When running the 3000 mAh battery the esc gets really warm within a few minutes and im afraid its going to burn up something.. So i my question is when going from a 1800 to a 3000 battery should the gearing be changed also? It has a 64tooth main gear and a 23t motor gear.. Im new to the truck stuff so any info would be great.
rsking45 is offline
Old 12-10-2011, 01:43 PM
Sunfirefoot
Sunfirefoot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Battery and gearing
Assuming the ESC is stock, you shouldn't have any issues with MAh changes, the only difference is longer run times. The gearing seems ok, but you could always cross reference the gearing with the RCUNIVERSE gear wizard calculator, it's very helpful. You could also try the touch method, when it's warm touch it and you should be able to hold your finger on it for at least 5 seconds if not more, if you can't, it's too hot.
Sunfirefoot is offline
Reply
Display Modes
