RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
Uncontrollable B4.1
Old 12-19-2011, 02:09 PM
DriftingFast
Default Uncontrollable B4.1
1 Week ago I upgraded both of my cars (TC4 and B4.1) to 2.4ghz. Since then I haven't been able to drive it because it goes backwards when I try to go forwards, vice versa, and it goes faster backwards than forwards. However I didn't have any trouble with my TC4.
Electronics
XP Digital SC450-BL ESC
Reedy 3300kV Brushless Motor
Futaba 4PL Transmitter
Futaba R2104GF Receiver
Possible Problems
I had to unplug the motor wires to clean the car.
The receiver/transmitter has to be setup.
Old 12-19-2011, 02:26 PM
nitrosportsandrunner
nitrosportsandrunner's Avatar
Default RE: Uncontrollable B4.1
sounds like you just need to swap 2 of the motor wires.
Old 12-19-2011, 02:29 PM
DriftingFast
The thing is that I do not know what order I should put them in; they came unlabeled.
Old 12-19-2011, 02:43 PM
DriftingFast
Ok...You were right...but it still goes faster backwards than forwards.
Old 12-19-2011, 04:23 PM
ORIGINAL: DriftingFast
OK, put the motor wires back the way they were....
then...
change the reversing switch on the radio(the throttle channel) then recalibrate the ESC to the radio.
Old 12-19-2011, 05:24 PM
dragnse7en
Banned
ORIGINAL: nitrosportsandrunner
then...
+1 - You beat me to the punch; I was going to say the same thing
Old 12-20-2011, 11:01 AM
DriftingFast
then...
I already tried that, it won't start if I do that. I have to have the throttle on normal, turn it on, and then put the throttle mode in reverse.
Old 12-20-2011, 11:07 AM
some ESC's only like the transmitter in norm or revs. sounds like yours likes normal.
so, i take it if you put the tx in norm, and program the ESC thats when you get the truck going backwards instead of forwards?
typically when you have an issue like yours its solved either by programing the ESC with the Tx in the opposite setting from what it was in...or just swapping 2 of the motor wires.
some ESC's have a "motor direction" setting. maybe yours does and it needs to be changed?
Old 12-20-2011, 11:08 AM
ThunderbirdJunkie
ThunderbirdJunkie's Avatar
You have to recalibrate the ESC if you reverse your throttle channel, as nitrosportsandrunner clearly stated.
DriftingFast
I fixed it. First I reversed the throttle, then I reversed the steering, and last but not least I had to re-calibrate the throttle settings.
