If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 8 of 8
  1. #1
    Join Date
    Aug 2007
    Indianapolis, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    New to me B4 issues
    Hi all! Im new to r/c cars but have experience with nitro planes and boats. I recently aquired an associated B4 buggy dirt cheap. Ive had a couple issues with is as to be expected from a used rc.. The screw that holds the servo arm has fell out. How in the world am I supposed to get it back in the servo?? Also I think I have an issue with my rx/ esc. I can run fine for a while and then the car acts like it loses signal for a second thenk I regain control.. Ive noticed if I flip the connection between the esc and battery I can cause this problem.. Any ideas on this? Again I am a total newbie to cars and electric! Thanks a lot!
  2. #2
    ThunderbirdJunkie's Avatar
    Join Date
    Jul 2004
    Norwood, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: New to me B4 issues
    To put the servo screw back in, you take the servo out, and then put the screw in, and reinstall the servo.
    If this is a car with a Tamiya plug, cut it off and throw it in the garbage and solder a Deans or Traxxas plug on it. The Tamiya plugs are horrible and once they get a bit of wear to them, they lose their connection and that would explain what you experienced with your car.
    If the servo is a Hitec, you need an M2.6x8mm screw. Otherwise it'll be an M3x8mm screw. If it's plastic geared, chances are good that the threads are pulled out of the splined output shaft.
    \"Some people can mess up an anvil with a rubber hammer\" -46u
    If you don\'\'t allow yourself to fail, you\'\'ll never allow yourself to succeed-ThunderbirdJunkie
  3. #3
    proanti1's Avatar
    Join Date
    Dec 2004
    Boerne, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Careful with the servo mounts, they are ridiculously easy to strip.
    Her name was Lola. She was a show girl.
  4. #4
    Join Date
    Jul 2004
    Norwood, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ThunderbirdJunkie never really had that issue.
    *EDIT*
    Nevermind, RTR has plastic
  5. #5
    Join Date
    Aug 2007
    Indianapolis, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Update... Got the servo screw back in.. It looked harder than it was to remove the servo.. Ended up cracking one of the crappy servo mounts so a hobby shop trip is in order.. ALso the connecter on the esc is a deans connecter already.. Should I try cutting off a cm or so, stripping and resoldering it back to the esc or just buy a new one?
  6. #6
    Join Date
    Jul 2004
    Norwood, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Nope, because Deans (at least real Deans) don't normally wear out. If there's any question on whether they're real or fake Deans, pop down to your LHS and get a new pack of them and compare them. The fake Deans are normally a redder red and a different material that one can dent with their fingernail.
  7. #7
    Join Date
    Aug 2007
    Indianapolis, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Update 2.. After taking the car to the hobby shop and finding my esc was messed up, I replaeced it and got some servo mounts.. Got the car running and it runs great! The only issue I have is after i put it into reverse even for a second, I cant go foward for a few seconds, on the other hand I can be going foward and just slam it into reverse at any time.. Im pretty sure this is bass ackwards because of a built in esc braking sequence or something.. Any ideas? Can I switch the polarity on the engine and servo reverse to fix it or is this a way to let the magic smoke out of my setup?
  8. #8
    proanti1's Avatar
    Join Date
    Dec 2004
    Boerne, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Something is backwards. Your forward is reverse. There is a servo reversal switch on your remote, hit that, then re-program your ESC (refer to the manual). It should now be going backwards when you pull the trigger. To fix this, reverse the polarity to your motor.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
