short course interchangable parts
WI
i have a helion dominus 10sc and im pleased with it, but i wanna change to either rpm parts or aluminum parts, they sell a kit on rcplanet for aluminum parts but i dont wanna buy it if it doesnt fit. shock towers, a arms, front and back bumbers, ect. also the spur gear i was wondering if i can change it to a metal or aluminum one thanks
WI
RE: short course interchangable parts
i dont think there is, atleast i didnt find one, i was talking about the aluminum kit for the slash http://www.rcplanet.com/Integy_Alloy...tt8547blue.htm cuz i either wanna buy that or rpm stuff for it, im going to start racing it but dont wanna break stuff inbetween races. also wanna know if http://www.google.com/products/catal...ed=0CGQQ8wIwAQ the spur gear will fit i just stripped the second one and i dont know why. really getting frustrated
I'll be honest I HIGHLY doubt most of those parts will fit. Besides the majority of them being absolutely worthless...
Generally when you start mixing parts made for other brands you have to have a pretty good degree of ability to modify it to fit. And not to sound like a *****, but seeing you are asking this question I highly doubt you have the skills that might be needed to modify slash parts to fit.
well after looking at the helion parts blow up I can honestly say I doubt any of those parts would work at all. It would require such heavy modification it would bea easier to just make the shock towers from scratch, along with most the rest.
Also do NOT get aluminum A-arms they are the WORST Hop-up for a RC
My Feedback: (30)
Oh see, you didn't specify that, that's ok though. No, regardless what you may have heard, slash parts won't fit without modifying the hell out of the main suspension mounting locations. It's not worth the risk because the functionality would be questionable.
ORIGINAL: Ducat1
Modification tool list...
1. Dremel
2. Drill/bits
3. Soldering Iron (for plastic welding)
4. Tenacity
5. Stubborness
A monkey has the skills to modify plastic, and piece it together
Do you have a LHS nearby that sells other brands of short course trucks?
Bring your truck down and just line up the parts side by side. You might find that an a-arm for say a Losi or SC10 are very close to fitting. A common mod required is usually going to be hinge pins (different diameter holes) which is easy with a drill and steady hand.
IL
ORIGINAL: SyCo_VeNoM
ORIGINAL: The Mad Modder
Especially integy ones. Their aluminum parts are infamous for bending easily.
Outside that the majority of their stuff sucks, and is just for show on shelf queens.
@someone got it already agree I've modified other parts to fit other RC's, also agree its VERY expensive to do once you start, and can be just a huge waste of cash in the end if it doesn't work out.
