Motor windings
Motor windings
Does heavy gauge armature windings give more motor speed or more torque?. I have two 550's and one has heavy windings and one has fine windings. I'm thinking the one with fine windings will be questionable.
RE: Motor windings
The gauge of the windings really only depends on whether the motor is a single, double, or triple turned. A 12x1 turn motor has heavy windings, a 12x2 has two sets of slightly thinner windings, 12x3 has 3 sets of even thinner windings. Single turned motors run hotter than double and are really hard on the comm/brushes, double runs hotter than triple. I know the Titan was originally a singled turned motor, then went to a triple to bring down the failure rate. You may have one of each.
WI
RE: Motor windings
To expand further then all the above what the winds mean to you
9 turn single has less resistance then a 10 turn single but a 9 double will have less resistance then a 9x1 and a greater magnetic pull hence more torque.
