Help Me WaterProof Hobbywing Xerun 150amp Sensored System
#51
Thanks for the awesome reply. Very helpful. I will be using the Arctic Silver adhesive. I will also see if i can find a stick-on pad. What do you think about the smaller circuits on the side of the silver bars?
#52
Also, i dont if I should get the alumina adhesive or the silver adhesive. The alumina adhesive wont short any circuits out in case it gets on the pins, but doesnt transfer heat as well as the silver. The silver is also twice as much, but you have to be twice as careful when using it.
#53
#54
Well, i should get the heat sink adhesive in a couple of days. Once i get it and install the heat sink i will post some pics. Once the heat sink is installed, i will than waterproof it.
#55
#56
I see what you mean dude. what i would do is find a way to stick the heat sink to it. or just set the heat sink and thermal pad on where there supposed to go, and then put liquid tape all around it and then put it back together. cause i don't think that the heat sink will move around and break the seal of the liquid tape when it's all back toghether.
