4wd traxxas slash Help
RE: 4wd traxxas slash Help
check the conditionof thelube or lack there of, check all the gears closely for wear, check all the bearings and pins, replace anything that looks questionable. you dont want to do it a second time just for fun.
Ok guys so the front diff isnt really lubed up , maybe i should put some in there ? and also my one way bearing my be stripped from the looks of it
Just to put my 2 cents in. They are right it is your diffs. Also maintain your bearings! Take care of them and thy will take care of you.
