VORZA 35T spur
VORZA 35T spur
Hi, does this spur gear kit can be good on my Vorza , Spur 35T ,Pinion 25
http://www.ebay.ca/itm/DIY-Upgrade-D...item27cae33584
can some one help me ...
My Feedback: (27)
RE: VORZA 35T spur
According to the ebay listing it will fit....but.... it will overheat your motor/esc and most likely your battery if you run it for extended periods of time. What battery are you running in it? 3s, 4s, 5s, 6s? You will see a masive speed increase if you are still running stock gearing but if you run for more than just a couple minutes your system will get very, hot very fast. Heat is your enemy! Heat will shorten the life of you brushless system and if you try to run for more than a few minutes with that gearing it will overheat causing exsesive damage rendering you car USELESS! If you run for more than a few minutes, put away the remote and get out the steaks. Your Vorza just turned into a BBQ!
So, will it work???? Yeah, it will work...for a few minutes.
RE: VORZA 35T spur
I haven;t done the numbers, but I reckon that gearing on 6S is good for 100mph. Is that what you are aiming for? If so, great, but the car will not be useful for anything else except speed runs, and only once or twice up and down before you'll need to give the electrics a rest.
My Feedback: (27)
RE: VORZA 35T spur
The Vorza comes with the HPI branded Castle electronics right? If that has the HPI equivilanet of the Mamba Monster 2200 syteme. My experience is you can safely gear it to run about 60-65 MPH in a 1/8 buggy without having to worry about temps. There are ofcourse variables such as drag and weight that will variy between different buggies. But if you gear it to run about 60mph you should be fine. (this is geared to run on 6s)
RE: VORZA 35T spur
ORIGINAL: yakfish
