Slash 2wd Brushless upgrade ??
My Feedback: (55)
Hello,
If any one can help me with gearing it would greatly help me. I am upgrading my stock slash to brushless KV 3900 10t motor . What Gearing should I start with???
Any help thank you.
Any help thank you.
RE: Slash 2wd Brushless upgrade ??
ORIGINAL: chesie2
Hello,
Any help thank you.
Hello,
Any help thank you.
Your motor is only 400kv higher than the vxl motor.
If you want to stay on the safe side, use traxxas gearing chart and go down 1 tooth from each reccomended gearing.
MD
I converted mine over to brushless over a year ago and its still running fine I had a use a 25/86 set up. Other than eating spur gears before switching to an aluminum one I have had no problems at all.
ORIGINAL: robausti
Temps range from 160 - 170
