RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
Trucks stutters bad
Reply
Old 10-18-2012, 03:49 PM
mtlrcguy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Trucks stutters bad
I am new to RC for the most part. I just got a used short course truck but it stutters no matter what I do when I press on the throttle. Both in forward and reverse.
What can it be?
mtlrcguy is offline
Old 10-18-2012, 03:52 PM
SyCo_VeNoM
SyCo_VeNoM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Trucks stutters bad
brushless, brushed?
as for stuttering could be many things
poor batteries, bad motor, bad ESC, radio dying, gearing, or bad servo(yes they can cause it)
SyCo_VeNoM is offline
Old 10-18-2012, 04:19 PM
mtlrcguy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ah sry, brushless.
mtlrcguy is offline
Old 10-19-2012, 02:46 AM
john01374
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If it's brushless then I would start with the battery... A dead battery or one that can't supply the necessary voltage will make the motor studder badly. Make sure the battery is fully charged and try again. If you know someone with a LiPo pack try that.
Poor signal would be my next guess. I had a RTR brushless truck that would move about 10ft then studder. Turned out the receiver was toast right out of the box....
My last two guesses are the most expensive to fix but could be the problem. An over heated brushless motor will act the way you are describing as well and there is only one way to fix that and it's replacing it. Same goes for the ESC. Normally when they overheat they just die. Sometimes they live one with poor performance.
Start with the battery and receiver and go on from there.
john01374 is offline
Old 10-19-2012, 03:52 AM
controlliner
controlliner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It may be a condition called "Cogging". It may happen if you are not pushing the amps to the motor. It may be the battery gone south, Worst case it may be a toasted field coil on the motor or the ESC.
controlliner is offline
Old 10-19-2012, 04:37 AM
phmaximus
phmaximus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
might just need a coffee, im like that in the morning.
phmaximus is offline
Old 10-19-2012, 07:26 AM
SyCo_VeNoM
SyCo_VeNoM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
BTW forgot to add the list of what I said could be wrong is what I would work from in that order
Problem with diagnosing BL trucks is that without a 2nd set of electronics its very hard to be 100% certain seeing you have to swap parts out one at a time
Sad thing is if it was brushed it would be way easier to diagnose
Old 10-21-2012, 05:29 PM
Sigma.40
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is it all speeds or just when you start to move? Does it smooth out when you give it more throttle?
Sigma.40 is offline
Old 10-22-2012, 04:40 PM
mtlrcguy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks everyone, I am going to try and get my hands on another ESC to try.
The battery is fully charged.
Sigma, its only when I start to give it a bit of throttle at the beginnig. Once I get the revs up it goes away.
mtlrcguy is offline
Old 10-22-2012, 05:00 PM
SyCo_VeNoM
SyCo_VeNoM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: mtlrcguy
that would be cogging generally from over gearing, or funky motor KV's
like I had a 1200kv motor that would do that like crazy. Turned out to be a defect in the companies 1200kv motors...
Old 10-22-2012, 05:24 PM
Sigma.40
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: mtlrcguy
As someone else wrote, its called cogging. And I believe its perfectly normal. My Stampede 4x4 does it and so did the Slash 4x4 that I used to own. I think it has something to do with not getting quite enoughvoltage (?) at first when you gently or slowly pull the throttle back. It happens to me the most when the LVC kicks on (which is when the esc cuts the power going to the motor). Its never gotten any worse for me so I, personally, wouldn't worry about it.
EDIT- Are you using NiMH? If you have access to a lipo or at least an NiMH with more cells try that. Cogging is lessened with a more powerful battery. Its almost nonexistant on 2S unless you REALLY pull the trigger back slowly. You could also try gearing down.
Sigma.40 is offline
Old 10-23-2012, 11:03 PM
BKoz559
BKoz559's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
To add to this: a LiPo is capable of supplying much higher current and thus cogging effects are often reduced.
The cogging itself is a fact of life with sensorless brushless motors. Until the rotor inside the can spools up and creates a current with one of the 3 coils around the can, the ESC can't detect it's oriention so the rotor will bounce back and fort a bit between two magnetic fields. Once it's spinning, the ESC can "see" the rotor's position and the timing of the coils will follow the poles of the rotor.
BKoz559 is offline
Old 10-24-2012, 10:23 AM
mtlrcguy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys, I will play with it and maybe just learn to live with it as it may be normal for what I have....
mtlrcguy is offline
Reply
Display Modes
