XXX-SCT gearing help
My Feedback: (9)
CO
I recently bought a XXX-SCT and installed a Tekin Pro / w 13.5 motor. I currently have the stock 88 spur and put a 21 pinion but am unhappy with the performance. I was just wondering if anyone out the has any suggestions on what i should gear this system at? I run a stock Slash with almost the same gearing and the VXL system and it has way more power and speed. Any advice is greatly appriciated
RE: XXX-SCT gearing help
I'd suspect that the motor system is the difference. Your Tekin is a 13.5T, but what is the VXL motor? Also, are the two vehicles' tire/wheel combos the same diameter? Are you monitoring the motor temp? That should give you a clue, too. If it's not very warm, go up in gearing, if it's too hot, go down.
Check out this thread, there are some really good responses, [link=http://www.rctech.net/forum/electric-off-road/676224-xxx-sct-gearing.html]here[/link]
Little tip for ya, if ya motor is not getting hot, gear it up... [X(]
