Eclipse Hobbies and Raceway Carpet Off Road Points Series
EclipseHobbiesand Raceway Fall Off Road Carpet Points Series 1
Visitwww.eclipsehobbies.com
8 Race series with 2 drops
100 points for 1st with 5 point reduction per place
1 bonus point for Top Qualifier
5 bonus points for entering all 8 events (must enter all 8 races in at least 1 class)
$10 for first class entered
$ 5 for each additional class entered
Transponder Rental $5
We use iLaps scoring system. Transponders are available atEclipseHobbiesfor $38 or herehttp://www.rclapcounter.com
Race points will be maintained here:
http://www.rcpointsmanager.com/viewe...psehobbies/120
Classes:
1/10th Scale 2WD SPEC Short Course Truck
1/10th Scale 2WD/4WD Short Course Truck OPEN
1/10th Scale 2WD Buggy OPEN
Race 1 Friday November 16th
Race 2 Friday November 30th
Race 3 Friday December 7th
Race 4 Friday December 14th
Race 5 Friday December 21st
Race 6 Friday December 28th
Race 7 Friday January 4th
Race 8 Friday january 11th
Race Awards Banquet TBA
Rules:
1/10 scale 2WD SPEC Short Course Truck;
Motor/ESC/Gearing:
Any commercially available 17.5 turn or 13.5 turn Motor may be used.*
Any ESC may be used.
*** When using 13.5 turn motor ESC must remain in Blinky Mode(NO boost and Zero timing)***
Reverse may NOT be used during a race. Penalties for using reverse will apply up to and including loss of lap, points, or disqualification depending on frequency of offense.
Any pitch gear and gear ratio may be used
Batteries:
Any 2s lipo may be used.
Up to 7s Nickel battery may be used.
Body:
Must use 1/10th scale Lexan or Polycarbonate Short Course Truck style body.
Chassis:
Must use 1/10th scale 2WD Short Course Truck native or conversion Chassis.
Tires:
Must use rubber tire. No foam tires allowed.
No Sharp pin tires allowed due to carpet wear. Race director has final discretion.
***The use of a 17.5 turn motor is recommended. 13.5 turn motor allowance is set in place due to the number of RTR trucks including 13.5 turn motors. If parity cannot be met with the above rules additional restrictions may be set in place for those choosing to use 13.5 turn motors.***
1/10 scale 2WD/4WD open;
Motor/ESC:
Any motor may be used
Any ESC may be used
Battery:
Any battery may be used
Body:
Chassis:
Must use 1/10th scale 2WD or 4WD Short Course Truck native or conversion Chassis.
Tires:
1/10 scale 2WD Buggy Open;
Motor/ESC:
Any ESC may be used
Battery:
Body:
Must use 1/10th scale Lexan or Polycarbonate Buggy style body.
Chassis:
Must use 1/10th scale 2WD Buggy Chassis.
Tires:
Thanks and lets have some fun Racing.
-Eclipse
Classes:
Rules:
Motor/ESC/Gearing:
Batteries:
Body:
Chassis:
Tires:
Motor/ESC:
Any ESC may be used
Battery:
Body:
Chassis:
Tires:
Motor/ESC:
Any ESC may be used
Battery:
Body:
Chassis:
Tires:
-Eclipse
RE: Eclipse Hobbies and Raceway Carpet Off Road Points Series
This is something I've always wanted to ask a race director: Why is it that reverse is not allowed at race tracks?
I can see that using reverse at the wrong time, i.e. in traffic, could cause secondary collision, but used with discretion I would think it would be usefull in just backin yourself out of a barrier. What is the rationale for No Reverse?
