ESC Question
ESC Question
How hot should an ESC get after a run? I put a newly purchased, recently charged 3000mah pack through my car. I've soldered some silver connectors to the leads off the ESC, and another set of connectors are soldered to the motor (so I can switch out motors if I desire). The motor itself was warm, and the comm end was a bit hot - I should probably add a drop or two of oil. The battery pack was lukewarm, as expected, but the ESC was too hot to keep a finger on for more than a second or two. It's an MC210CB (standard esc from an older futaba am radio package), but it should be able to handle a stock motor like I've got.
Am I being paranoid? I don't like all my juice going to heat like that. More to the wheels!
I suppose I should check the connectors for corrosion, but if that's where the resistance was, I expect the housing would have gotten hot / melted.
Is my ESC:
a) fine - I'm just being silly
b) not quite up to the task and needs replacing
c) somehow damaged (and needs replacing), but should normally have been able to handle the situation?
If it does need replacing, what are suggestions for a new one?
Thanks for the input, and for tolerating my newbie questions.
Is my ESC:
RE: ESC Question
Your answer is somewhere between a) and b).. Likely it isn't a very nice ESC, so it has to work semi-hard even to push the stock motor. Technically speaking, your ESC shouldn't be hot at all, rather warm. Your motor on the other hand can get fairly hot, and be just fine. Make sure you clean your motor every couple runs at least, and make sure you re-oil the bushings after EVERY run.
