am I the only one?
Funny how we all seem to have different "favorites". Guess it all depends on one's experience. Me, I found that phillips would strip out too easily. Unless you know you have a #2 phillips screw and you use a #2 phillips driver (which I think is very hard to eyeball) you're gonna strip the sucker. For that reason, I hate phillips, and I find that hex heads don't do that, providing that you have a good, un-rounded, hex driver. ANY fastener on the bottom of a car is gonna need dirt dug out of it before using the appropriate driver.
#31
Hate to resurrect an old thread, but I had to come back.....not two days after I posted here, I went out to work on my car, and the first hex screw I went to take out with my hex driver stripped out! D'OH! Had to go get the dremel and carve a slot in it to get it out. I need to get some better drivers I guess.....
#34
How's.... I forgot to mention, I use to have a HPI E10 and swapped all the screws I could with the HPI alloy purple screws....
Now they are easy to strip... All it takes is a slightly worn hex driver
#39
the things you have to do to have an E10 not break from normal running lol
#41
