RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
ecx boost tranny issue
Reply
Old 02-13-2014, 07:35 PM
mxrider282000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default ecx boost tranny issue
I went up to my local track last weekend to practice I ended up coming home with an ecx boost it was cheap and handled surprisingly good well needless to say I got bored of going slow and put mamba side winder3 in it on a 2s and now it's ridiculous but the tranny doesn't seem like its going to hold up and the driveshafts look weak anybody ever build one looking for some advice on how to beef it up
mxrider282000 is offline
Old 02-14-2014, 08:05 PM
collector1231
Moderator
collector1231's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.amainhobbies.com/product_...FZDm7AodfGsAmQ
http://www.ebay.com/itm/like/271401586992?lpid=82
collector1231 is offline
Old 02-21-2014, 08:04 AM
stevenator128
stevenator128's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you have a properly adjusted slipper clutch and set your punch and brake levels to something reasonable you can survive with the stock transmission and driveshafts. You'll need to research and find out what version you have as well because it might already have the ECX HD shafts linked above. Was the ESC or servo waterproof when you bought it?
stevenator128 is offline
Old 02-21-2014, 10:07 AM
EXT2Rob
EXT2Rob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Collector, does that differential have pins behind the large bevel gears that go thru the drive cup shafts?
When I converted my Evader to brushless, those pins would break, and then the diff gears would get munched. I learned about using Music Wire for those pins in the diff and for wheel drive pins. That stuff NEVER breaks, and you can buy bundles of three 30in lengths for like $3. Cut pieces to length and you have a lifetime supply of pins for pennies!
EXT2Rob is offline
Old 02-21-2014, 02:02 PM
collector1231
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not sure Rob, although I have about 10 rods of assorted piano wire myself, LOL!
Old 02-21-2014, 08:36 PM
stevenator128
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If that stuff never breaks why do you need a lifetime supply?
Old 02-21-2014, 09:14 PM
EXT2Rob
EXT2Rob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ha ha, good question. Well, in most cases, wheel drive pins in particular, since they aren't spring pins, they don't fit tight enough not to fall out, if say, your wheel nut comes off. You loose the things before you break 'em.
EXT2Rob is offline
Old 02-22-2014, 05:02 AM
phmaximus
phmaximus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In the past I've fitted those alloy hex's with the little clamping screw... It solved 2 problems
Each time I removed a wheel the hex would get stuck in the wheel and the pin would fallout.
worn out wheel nuts.... If the wheel came a little bit loose it use to drop the pin.
phmaximus is offline
Reply
Display Modes
