What kind of servo can my receiver use?
Does anyone know what kind of servo works with this Its an HRS 3.1 HLNA0226. the one i currently have looks like a JR but has red white and black wires...
Also any recommended servos for this would be appreciated.
Thanks so much
Thanks so much
I had one from an old iron track bowie (piece of crap i know) that had a connector with a lip on the side of it, and that one wouldnt work. i even tried trimming it so it would fit and it didnt go through, is there some kindof setup i need to do?
No basically any 3 wire servo should work if you plug it in right as the signal to control it is a standard. That is assuming the servo, and receiver work.
Channel 1 is steering, channel 2 is throttle, channel 3 is the aux button (if your radio has it)
Generally is black wire to the outside on the RX's I've used
