Official Caster Racing SK-10 4WD 1/10 RTR Buggy
This car is a great entry level to intermediate racer package. The expert racers will want more power, but if you are just starting out this is a great setup. There are a few aluminum upgrades that make this kit hard to beat. It is approximately 75% compatible with the S10B pro kit so that you can upgrade any time that you want.
Specs:
CNC Front Arm Holder
Front CVD Drive
Threaded Big Bore Shocks
Full ball bearings
Gear Diffs
Adjustable slipper in the center.
Fully adjustable turnbuckles.
Front & Rear Toe in adjustable system.
Racing Hinge Pin for front and Rear.
3.5mm Heavy Duty Shock Shaft.
Full Hex Racing Quality Screw.
Alloy Hex Adaptors
Alloy Shock Body & Cap
Servo Saver System
Bulldog and Rear Cab Pre-Painted Bodies
Low Balance CG design.
10kg servo
8.5T 4000KV Nova Brushless Motor
Hobbywing Brushless 35A ESC
Metal Crown & Pinion Gear
Plastic Main Chassis
Length: 365mm
Width: 247mm front, 250mm rear
Wheelbase: 280mm ± 2mm (adjustable)
A 7.4V lipo battery is needed to complete the kit.
It comes assembled and ready to run.
Uses a stick pack battery layout.
Suggested Mods:
SKOP008 - Alloy Rear Turnbuckle Holders
SKOP002 - 6061 Alloy Front Shock Tower
Retail price $259.95 at http://www.casterrc.com
Most spare parts can be found at these dealers:
casterrc.com
amainhobbies.com
casterracingparts.com
Specs:
Front CVD Drive
Full ball bearings
Gear Diffs
Alloy Hex Adaptors
Servo Saver System
10kg servo
Length: 365mm
Suggested Mods:
casterrc.com
amainhobbies.com
