ae-2 esc
ae-2 esc
So my honcho has the stock esc still.
My ? Is, is the lipo cut off not on from factory? I was out running it just a bit ago and it got super sluggish and I thought ok since its lipo I need to stop so I did. I plugged my batt in and it said 6.94v. If its not turned on which im thinking not, how do I turn it on?
http://www.axialracing.com/products/...9/instructions
There's 2 links on the page for instructions. I'm sure the answer is in there somewhere.
I'm 99% sure they default to auto...
been a very under geared crawler the voltage under load is going to be very close to the surface voltage...
as long as it's not draining the battery below 6v ideally 6.4v ur fine
