Servo Help
Servo Help
I am building a Tamiya cc01 using the stock esc can i run a savox sc1258tg or do i need a separate receiver pack. I do not want to use a external bec because I will be away while building this and i won't have my soldering equipment. Also Should I get this one with 166oz in of torque, theSA1231SG with 444ozin of torque, or the sc1231sg with 305 ozin of torque. I will be useing this servo in my HPI Bullet Mt Flux.
Please help
Please help
Hummm.... If it's the stock TEU-104BK ESC it has no BEC... So what ever voltage the battery is that's what it sends to the receiver and then that sends it to the servos.
since u don't have access to a soldering iron. U need to make sure the servo and receiver can handle un regulated battery voltage.
and that particular servo u mentioned can't. If u are running a 6cell nimh or a 2s lipo u will need a high voltage servo rated for 7.2v-8.4v and as well as that u will need a receiver that can handle up to 8.4v
so yes u could run a receiver pack with that servo but u would have to back out the red wire on the connector from the ESC to the receiver and tape it up.
but I'd highly find a way to take a small soldering iron or buying one where user u go? Even a pocked butane one would work? But if that's 100% not possible I guess the best bet would be to run a receiver pack.... Or get a better ESC
