Jeep Brute Double Cab
http://www.rccrawler.com/forum/gener...e-rigs-19.htmlSOMEONE BEAT ME TO IT!!!!!HERE IS WHAT I STARTED ON THE BUILD 2 1/7 YEARS AGO.So to make this happen you need to cut behind the door and add 1.5"-2" and made a new bed, here is a picture of a FJ40 that shows what I mean.The custom frame will be Aluminum and will be set up much like RCMODELex sets up his drive train.
I will also change the rear window. I will look like the real truck. You can see that I cut the plastic off the running boards and read bumper. I will be using a scale motor cover to show off the drivetrain under the hood muck like my JK 1/6 build.All these pictures are old 2-3 yrs so when I restart I will post current ones. I have a build that I'm working on currently.
It's hard to see because of the protective cover on the Lexan but the window is in. I have more to do such as cut the center out and add rails on the edges and trim around the frame. and lots of sanding. Oh by the way my fingers never get tired of sanding because I wrap sad paper around the hacksaw blade and use it as my finger. Try it it will save time and it is clean way to get even sanding done.
I just ordered some parts to keep the build going. I have the RC4WD T1 Disruptor Black Transfer Case (2.18:1 Gearing) and a set of drive shafts JUNFAC HARDENED UNIVERSAL SHAFT (95-130MM) 5MM HOLE on the way also. And some more WHITE STYRENE on the way. should be another week before the parts show up.
This is the reason I didn't do the long bed. I wanted the frame to work with this body also. It's going to be a FJ 43 ICON when it's done. the light bucket are Proline and the front floor has been modified also. It will have a roll cage and removable hard top. I need to come up with some working tail light lens. Any ideas?
