Hunter SCT
Hunter SCT
DHK Hobby has just released a new Short Course Truck that is 1/10th scale 4wd. It is on the cover of the current issue of RC Car Action. Also Car Action made this video of the truck, check it out.
http://www.youtube.com/watch?v=kJP8Y6ESDBg
There are two versions available, Brushed and Brushless.
Be sure to check them out!
Looking at that chassis it appears to use a lot of the same parts as the Redcats, Himoto and Exceed trucks. They're not bad designs but the plastic was way too brittle on those other models. Hope they solved that problem for this truck.
Fortunately you are completely wrong on that assumption.
DHK manufactures every part of their trucks. They do not source any chassis components for other manufactures. They have their own plastic formula that seems to be doing very well. Basically everything is done in house. This is unheard of in this hobby anymore.
Here it is a month later. I've been thrashing hard on my Hunter. I've bent two screws in the bumper and broke a suspension arm because I ran it into a curb at full speed.
I am really shocked I have not broke more parts. I wonder what will wear our first...
Looks like a lot of parts used on this one and the Razr and Wolf. Myself, brother and brother in law have Razr's. They have been pretty good so far. Only issues are we lost (2) steering servo's to bad driving, a few broken screws for same reason. For what we spent they are a good deal.
Buzz.
Buzz.
CA
I've had the DHK Hunter BL (brushless) well over a month now, my grandson has the DHK Wolf (I upgraded to Brushless shortly after buying it for him - the stock brushed motor toasted in a few days). NO OTHER model is the same as the Hunter. Not the Turnigy, Not the Redcats, Himoto and Exceed trucks, we've seen them all at the local tracks. And shares little to nothing with the Wolf or Raz-R, since we have one I can verify that. The Hunter is really more of a 1/8th scale truck since it does use and share many parts with the DHK 1/8th Zombie (again, I compared the two with bodies off at the local Hobby People store.
My only complaint with the Hunter B or BL is the cheapo plastic gear steering servo, which I replaced immediately with a digital Metal Gear unit (TowePro MG966R ... a bullet proof servo)
With some detective work (comparing dozens of RC Car ESC's) I'd like to report that the ESC's used in the DHK Hunter BL and perhaps other models, are made by HobbyWing. To me, a 45 year Fixed Wing RCer and 12 year Electric Plane RCer, it means DHK is using quality brushless electronics. HobbyWing is the best ESC from Asia (Japan, Taiwan, Korea or China), highly reliable. Jack from DHK China Product management "sorta" confirmed this when I asked by email if the HobbyWing Brushless ESC Programming Card would work on the their branded ESC. I already knew the answer since the HobbyWing EZRUN user manual is copied into the DHK Hunter BL owners manual for programming instructions.
So I ordered a HobbyWing EZRUN Programming Card ($10 online) and sure enough it reads all the "Item" and "Value" settings pre-programmed into the DHK 45A ESC and allows you to change them. A warning - I found that the factory is not enablling low voltage protection for the LiPO battery, I reprogrammed mine to 2.6v p/cell cut-off.
I hope that 2.6v p/cell is a typo. Lipo batteries should not be allowed to have their voltages go below 3.0v p/cell or damage can occur. It's generally agreed that 3.2 v p/cell is the lowest you should go as it provides a margin of error since the esc doesn't knowindividual cell voltage only average voltage of the cells in a pack.
CA
Under a heavy load, 2.7v per cell should be fine. Under a medium to small load 2.7v per cell cutoff is not so good. But this all hinges on the quality of the cells you have purchased. Poor quality cells will not recover. Also, if you are using 3cell packs or larger, it is safer to use a 3.0v per cell cut off. We are not matching internal resistance and voltage of LiPos, so each cell could reach their minimum voltage at different times.
