RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
Im sick of messing with the vxl esc's they are junk. What can I replace with?
Reply
Old 08-12-2014, 01:46 PM
hanly2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Im sick of messing with the vxl esc's they are junk. What can I replace with?
Like the post says. I keep having to replace these things, and they are not cheap. What is a good alternative, for my stampede?
hanly2 is offline
Old 08-12-2014, 07:26 PM
josh h
josh h's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had to replace the esc in my mini revo when the stock one went up in smoke about 2 weeks of having it. I used the castle sidewinder and have had no problems at all. It's actually a 1/10 scale esc so I'm sure it would work fine. I ran 3s all the time with the esc in in one battery tray and the battery in the other. I've had the motor get real hot on me but the esc was still cold, even being enclosed in the battery box. Maybe someone else will chime in with their experience with others.
josh h is offline
Old 08-13-2014, 01:17 PM
BKoz559
BKoz559's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What is happening that you need to replace them? What I'm getting at is there may be another issue causing the ESC to fail which could happen again even if you use a different make / model.
BKoz559 is offline
Old 08-14-2014, 10:45 AM
EXT2Rob
EXT2Rob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah, like using NiMh batteries instead of Lipos. If you've been using NiMhs, I'll betcha that is what is killing your ESCs.
EXT2Rob is offline
Old 08-14-2014, 05:06 PM
SyCo_VeNoM
SyCo_VeNoM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
He said 3s lipos.
on that the gearing for traxxas RC's is not suitable for running 3s for extended durations as they are geared way too high.
SyCo_VeNoM is offline
Old 08-15-2014, 09:14 AM
EXT2Rob
EXT2Rob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by SyCo_VeNoM View Post
He said 3s lipos.
Where did the OP say he uses 3S Lipo? He DIDN'T. In fact, he didn't tell us much at all, as to his setup, other than he has a VXL. Bkoz said he's run 3S in his MERV. Were you drawing a correlation between Bkoz's MERV and the OP's Stampede? That being, Traxxas tends to gear their cars too high in general? I might buy that. If that is the case, then every Traxxas owner should own an IR thermometer, and probably, gear their car down a tooth.
I maintain, however, that brushless systems and NiMh batteries are not good for each other. I bet the OP comes back and confirms he's been using NiMhs.
EXT2Rob is offline
Old 08-15-2014, 10:27 AM
SyCo_VeNoM
SyCo_VeNoM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
sorry sorry didn't notice I missed the 1st post entirely somehow. my reply was more for the 2nd post on it getting real hot, and frying an esc.
Side note Bkoz didn't mention a merv
weird a stampede fried an ESC as those things can run on almost any 1/10th scale ESC they are so light (unless its a 4X4 then it is extremely possible it fried as those almost need a 1/8th ESC)
agree on brushless, and NiMh's I don't know why companies even give NiMh with BL RC's anymore its pretty stupid.
Old 08-15-2014, 12:03 PM
josh h
josh h's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I said 3s. Referring to my sidewinder holding up very well 3s with absolutely no heat problems.
josh h is offline
Old 08-15-2014, 12:13 PM
SyCo_VeNoM
SyCo_VeNoM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you said you had the motor get hot that would be a gearing issue.
The ESC shouldn't get hot as its meant for a vehicle that weighs like 2X more, and a motor that pulls almost 3X more current lol
Old 08-15-2014, 06:22 PM
DieHarder
DieHarder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I accidentally shorted one out once. It still fully functions, despite the little burn hole. They run hot, but I have not managed to break one. I run 2S though, that seems to be a good middle ground between NiMh and 3S. It definitely needs LiPo to run correctly.
DieHarder is offline
Old 08-16-2014, 03:47 AM
phmaximus
phmaximus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Generally the VXL is a good reliable ESC, I personally don't like it due to the lack of tuning options.
as for replacing it with something better.... hobbywing Ezrun series. There are a few ESC ranging in different specifications.
But.... U say they VXL is junk,
what happened?
how many times has it happened?
is u stampede completely stock??? Have u touched the electronics at all, ie. Ext. BEC, LED lights... Anything?
phmaximus is offline
Old 08-19-2014, 10:57 AM
guys2nv
guys2nv's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hobbywing Ezrun SC8 WP.
http://www.ebay.com/itm/HOBBYWING-EZ...item4d16862604
guys2nv is offline
Old 08-19-2014, 11:22 AM
BKoz559
BKoz559's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rob, that was Josh talking about the MERV, not I. That's beside the point. I have had my hands on several of the Velineon ESCs over the years and they don't usually die easily. I agree that the worst part about them is the lack of tuning options. Interestingly they can run a sensored motor.
I can't say anything about the EZRuns other that I generally read good comments about them. I'll have to try one myself.
Castle is in the same category as Traxxas and Dynamite in my book except that they have the tuning ability and the Castlelink is convenient. I have a couple Castle ESCs myself but they're not my favorites. Relatively inexpensive and easy to obtain. My favorite at the moment is Viper. I have a Copperhead 4x4 SC system with a 550 can and it's making a name for itself!
BKoz559 is offline
Contact Us Archive Advertising Cookie Policy
