RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
Want to start in RC Cars.
Reply
Old 08-18-2014, 07:16 PM
zarnold16
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Car - http://www3.towerhobbies.com/cgi-bin...&I=LXEDYL&P=ML
Battery - http://www3.towerhobbies.com/cgi-bin...?&I=LXYYZ7&P=0
charger - http://www3.towerhobbies.com/cgi-bin...?&I=LXAGUG&P=0
This is everything I'm gonna buy in October. Is there anything else I may need to start out in rc cars?
zarnold16 is offline
Old 08-19-2014, 07:04 AM
EXT2Rob
EXT2Rob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Diff fluid http://www3.towerhobbies.com/cgi-bin...RCH=diff+fluid
I'd suggest 7000wt for front and center diffs, 5000wt rear. They come from the factory with a little grease in them. Clean 'em out and put in the fluid.
Lubricant: http://www3.towerhobbies.com/cgi-bin...?&I=LXATCH&P=7
degreaser for cleaning bearings: http://www3.towerhobbies.com/cgi-bin...&I=LXSEL1&P=ML
If you don't have a good set of hex drivers you'll need some. Buy quality first. MIP make good ones. You'll need 1.5mm, 2.0mm and 2.5mm.
IMO, you're over-paying for that Venom battery, but you apparently have the means, and prefer ordering everything from Tower. That's cool. But you can save considerable money if you consider alternatives. At least well-known alternatives. Some call it "cheap Chinese junk", but in my experience, they're just as good as anything else. Cheap servos can be dodgy, but batteries, motor systems and chargers, if you know the right brands, work great and are considerably cheaper.
EXT2Rob is offline
Old 08-19-2014, 07:42 AM
zarnold16
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Then what 4s battery from tower hobbies do you prefer? I went with venom because I have heard of that brand.
Old 08-19-2014, 06:45 PM
EXT2Rob
EXT2Rob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry mate. Nuthin wrong with that battery, AFAIK. I'm just a cheap bhazterd and wouldn't pay $130 for something I could get for $82, that's all. Even if I do have to solder on my own connectors.
EXT2Rob is offline
Old 08-19-2014, 07:33 PM
BKoz559
BKoz559's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good choice. You won't regret it.
You're going to need TWO Lipos. OR one 4S Lipo...
You might want to consider getting a 3S Lipo to use while you learn to drive that fast buggy, and get a 4S later, when you've gotten to be a good driver and not hit stuff. 4S is a LOT of power.
Whatever battery you choose (and I do recommend those two above) I highly suggest staying with lipos rated 40C minimum. That rating is indicative of how much current (amps) the pack can supply. If a motor system tries to draw more than the pack can comfortably deliver, the pack can heat up. A little is ok, but too hot, and they can puff, or swell. In which case, the battery is suspect. So don't be tempted by the less expensive packs that are only 25C.
NOTE that you will have to change the battery connector to match the Deans connector on the car. If you don't know how to solder, get someone to do it for you.
Sound advice.
Also consider this, like most 1/8 vehicles there are probably 2 connectors on the ESC so, he would have to un-solder the "Y" and make it into a single connector to run the 3S pack. I used to have the older Ofna buggy 8e and it was a tough buggy. It was by no means quick and the instructions advised that altering gear ratios would void the warranty. I think it had a Leopard 1/8 in it. The specs on the SSe look better than the 8e so I imagine this wouldn't be an issue. The only gripe I had about it (probably because it was being discontinued) was that parts were difficult to obtain.
I wanted to touch on the Traxxas brushed 4x4 for a second. The bogus part about them is that Traxxas made them brushless "un-friendly" by using a plastic driveshaft instead of the aluminum tube on the brushless versions. You would have to upgrade this part too.
BKoz559 is offline
Old 08-19-2014, 07:57 PM
  #31
SyCo_VeNoM
SyCo_VeNoM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
wow that is pretty low of traxxas to do
SyCo_VeNoM is offline
Old 08-19-2014, 08:28 PM
  #32
domer1234
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
welcome to rc car, There are a lot of rc car that you can choose. Hope fun.
domer1234 is offline
Old 08-19-2014, 09:42 PM
  #33
Muskokarc
Muskokarc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All sound advice for getting into the hobby. One word of advice is when you start to upgrade parts be careful not to go over board with them. If you see a bunch of stuff you thing are cool and shiny add them to you wish list but then as you did for picking an new RC ask others about what they have done with their upgrades and hop ups. Some will make you machine better others just look good but where not worth it in the long run.
My one friend is and example of going over the top. He got a Traxxas Rustler new and ready to run a fine truck (I have one myself one of the first generation). Well he started looking at what he can get for upgrades and such. He got hooked on the shiny aluminum parts and replaced almost every part to the point he ended up with two rustlers using the reason that he would give the plastic one to his kids to use. The new shiny one looked great but became quite heavy he was trying to make it bullet proof but you need a good mix of original and new to get a good result I have found and save on money. With all his upgrades his like mine when he lost control of his truck at full speed and hit a unmovable object need much repair.
I had caught a bit of the bug to and did a bunch of upgrades to my old rc but money well lack of helped keep me from going over the top and got what I needed to bring it up to today's rc abilities and some bling to. Thats my ten cents worth all in all would say enjoy the hobby and have fun with it do your research before you buy as you have and it can save money and keep it fun.
Muskokarc is offline
Old 08-20-2014, 11:37 AM
  #34
BKoz559
BKoz559's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I love that TrakPower Krytech lube. I use it on CVDs, hinge pins, ball joints. Great stuff!
In regards to batteries:
I have a mixed review of Venom batteries. On one hand they have a "life time" warranty if you keep your receipt. There are terms and conditions to the warranty but they have replacement coverage for the first year. On the other hand I've seen several of their packs come back to the shop with customers wanting to file claims because they've "puffed" or I've seen the wires break inside the case. We can argue that the owner was probably not caring for them as they should; and I would probably agree. But the Turnigy packs I've been getting from HobbyKing hold up a lot better. You can get a pair of 2S 40C packs shipped to you for about $60.
This is an example: http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
There are many choices but I agree with Rob, these "Chinese" packs offer performance that often times rivals that of "name brand" packs for literally half the price. The Turnigy's are my personal favorite but I've also used Zippy's. My brother swears by Gens Ace from Hobbypartz. Lots of other folks speak highly of them too. We can offer suggestions and such but the essentials are that you choose a pack that can support the amperage and preferably is rated at least 5000mAh.
BKoz559 is offline
Old 08-20-2014, 03:57 PM
  #35
SyCo_VeNoM
SyCo_VeNoM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've had one gens ace... I put it in storage with 3.7v a cell about 8 months ago(I do this on all my packs once I'm done). Pulled it out 2 months ago as I had an itch to run my merv the cells read 2.1 volts... I checked all my other batteries some which I've not used in 2 years(as the RC's they are for I've not bothered with) they still all read 3.6-3.8 volts. The other lipos were Sky, Trunigy(held the storage voltage the best), and a few other cheap ones that I can't think of the brand.
Not sure if it was just one bad battery or what.
Old 08-20-2014, 04:21 PM
  #36
EXT2Rob
EXT2Rob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow, my buddy and I have been using Gens Ace since going lipo three years ago and have never had that happen, Syco. That's a bummer! And of course, you didn't keep a receipt, huh? Me either. lol I think you were un-lucky and got a bad one. The Turnigy held the best charge, huh?
EXT2Rob is offline
Old 08-20-2014, 04:30 PM
  #37
stoneenforcer
My Feedback: (23)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
traxxas all the way for a long lasting durable backyard RC
stoneenforcer is offline
Old 08-21-2014, 09:33 AM
  #38
BKoz559
BKoz559's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I haven't used a GensAce personally but so far the Turnigy packs hold up for me. I've had a Losi that was stored for almost a year, the voltage was around 3.8/cell but I could see a buldge in the case. I've used it a couple of times since and it hasn't gotten worse but that still ticks me off! There's no turning back at that point.
A Zippy 6S for my helicopter, however, sat for about 3 months initially at around 3.8V/cell and when I brought it out to use again, two of the cells were way down around 2V. My charger wouldn't begin the charge cycle. I had to "tap" into the balance lead for those cells and slow charge them a bit to get the voltage up with the other cells. From there a normal balance charge brought it back. My charger shows resistance of the cells too and those have more resistance than the rest. I have another Zippy 6S just like it and it didn't have this issue. One of those flukes I guess.
BKoz559 is offline
Old 08-21-2014, 06:33 PM
  #39
SyCo_VeNoM
SyCo_VeNoM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yup, and I put the turnigy through a lot of load as its a 5200mah 30C battery I've used them on my Savage flux, and 1/8th truggy.
The gens ace was used in a brushed merv, and a RC18b(brushed) a handful of times. I was also planning to use it in Vaterra Kalahari that I forgot I bought for awhile as it has a smaller battery tray like the merv.
But yea I figured I got a bad battery which why I didn't go around saying they are crap like some people I've seen that get one bad product the 1st time, and decide all are the same. Was planning on buying another 2 when I get some spare cash to waste, then if both of those would have issues I'd say they were crap .
Old 08-25-2014, 06:03 PM
  #40
domer1234
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I suggest Traxxas RC. No any problem on it. So fun!
http://www.youtube.com/watch?v=TsGvIoQrtvE
Old 08-25-2014, 07:16 PM
  #41
collector1231
Moderator
collector1231's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And if you velcro seal the body on, you wouldn't really need to waterproof it.
collector1231 is offline
