Summit XL Scale Build
So this is going to cover a build that uses a 3.3 alumimum chassis that is cut and stretched to 18.5 inches or 47 cm to fit the new Yeti XL body. Parts that will be installed will include the following:
1/5 Beadlock Wheels
2 Speed Summit transmission
1/5 scale HS-5575MG Servo
RPM Axle carriers
RPM upper and lower Control A-arms
4074 2200kv sensored Leopard motor
LRP iX8 Speed Control
1/10 Aluminum 7075 Differential Cup And Hardened Gear Set From LeadingEdgeMachining.net.
E-Revo spider gears
Custom Drive shafts
Axial Yeti XL body and cage with interior
Led lights front and rear
Long Travel Rocker arms
Steal hardened drive CVD axles
Custom Bumpers
24mm Wheel adapter
Variable Rate shock springs
Hardened Shock bodies and aluminum collerand end caps
Aluminum piviot balls
7075 Aluminum Push Rods
7075 Aluminum Tie Rods
Aluminum single servo steering arm
Titanium hing-pins
SMC 9400 2s Lipos (pair)
Custom Lipo mounts
https://www.youtube.com/watch?v=6tmcuzLQo0w
1/5 Beadlock Wheels
RPM Axle carriers
E-Revo spider gears
Custom Drive shafts
Custom Bumpers
24mm Wheel adapter
Titanium hing-pins
Custom Lipo mounts
I'm not shure. I have had a lot of the parts for awhile and so I don't keep track. As for the new parts I buy a little at a time and when the deal is good keeping cost down.
I ordered the 3.8 BFG Krawlers today. I also picked up a new esc to try. It's a SkyRC Toro-8S 150A ESC for 1:8 sensored/sensorless RC 2-6s LiPo+capacitors that I found on ebay. It's being shipped from china so it will be awhile before I see it. The tires are from NY so they should be here in a week. I got a smoking deal on them 55.00 set of 4 shipped!
I also bought a pair of 1300 20c reciever packs to run the 1/5 scale hitec 5575 servo on 2s. That should turn the big wheels and tires with no problems!
