spektrum s6030
spektrum s6030
Soooooo I bought a spektrum s6030 servo for my wraith. The hitec 645mg stalls out when trying to turn the wheels granted the tires are rc4wd Baja claws and I have 3oz of weight in each wheel and the tires r like almost 6in tall. So I'm hoping this servo has the balls to turn my wheels lol.
Also I have a castle mamba max pro powering it, I would like to know how to set my MMP to 6v for the internal bec I think it said 5.5v is default but for as much as I paid for the servo I want to be able to use the full torque not be .5v short and I also don't want to buy an external bec, I'm done buying crap for my RCS for a while now. Lol!
I already have the castle field link program card thingy, I don't have the USB one. I tried looking on castle website and it just says variable 4.8-7.2v but I can't figure how to set it.
This is the Spektrum S6030 Digital High-Torque Surface Servo.* This servo has metal gears and 278 oz-in of torque, making it perfect for most 1/10 scale applications.
Features
Delivers torque with silky smooth precision
Heavy-duty
Dual ball-bearing output shaft
Overload protection
8 inch 22AWG lead
Mounting lug height optimized for surface applications
Overview
The heavy-duty, metal-gear S6030 puts out an incredible 278 oz-in of torque making it the perfect 1/10th scale* servo for monster trucks, buggies and truggies.* And it delivers this torque with silky smooth precision thanks to its dual ball-bearing output shaft.
*This servo is not recommended for 1/8 scale off-road applications*
Specifications
Size Category:*Standard
Type:*Digital
Application:*1/10 scale servo for monster trucks, buggies and truggies
Torque:*20 kg-cm / 278 oz-in @ 6V
Speed:*0.15 sec/60 deg*@ 6V
Length:*40mm
Width:*20mm
Height:*37mm
Weight:*52 g / 1.8 oz
Bushing Or Bearing:*Bearing
Bearing:*Dual
Motor Type:*Coreless
Gear Type:*Metal
Gear Material:*Titanium
Voltage:*4.8V or 6.0V
Features
Heavy-duty
Overload protection
8 inch 22AWG lead
Overview
Specifications
Type:*Digital
Length:*40mm
Width:*20mm
Height:*37mm
Bearing:*Dual
Gear Type:*Metal
I'm just guessing here, but Castle (and other ESC companies) saw $$ when they took out the USB hookup from their original Mamba Max speed controls and offered "links to the computer" as an option on Mamba Max Pros.
Sorry for jumping in and throwing a mini hissy fit.
Well gentlemen, the Rc gods r looking out for me. My Grandmal from Indiana sent me a amazon gift card so I'm going to figure out how to use amazon and order a cc bec and a servo horn, the plastic on that comes with the spektrum servo bends all over the place.
Also another question, when I turn my wheels the servo only seems to turn to about 45° even though it turns to 90° I I adjusted my endpoint from 100% to 150% and it turns far enough to get the full steering range my wraith will allow but it doesn't stall. I hope that was the appropriate way to fix that.
Oh, should I get an aluminum servo horn or just go for a thicker plastic one that won't bend?
The ones that came with it are a small circle a large + and a medium size 6 point star.
When I use a higher torque servo, an aluminum arm usually follows, if I can get one to fit, that's just my preference.
Yeah, some of those stock arms that come with servos are "soft". Hitec usually gives an aluminum arm with their servos.
My hitec one didn't have a metal one it had a super beefy looking plastic one. After some looking in the vast jungle of s#¡t I have I found an aluminum servo horn.
I tested everything out for just a second in my living room and it won't steer and go forward at the same time. If I stop it will steer and if I have the steering wheel neutral it will move forward and backwards. Good thing I already ordered the bec I guess.
The spektrum is a rebranded savöx pretty much yeah.
I got the became on order, its coming from new Hampshire to here(Arizona) so it'll probably be next week b4 I can drivey wraith again :/ at least my exo and honcho are still good to go lol.
However what's weird is that my exo has a hobbywing sc8 ESC, a spektrum avc receiver, and a savöx 1256tg servo and it doesn't brown out.
Those 2 servos are very similar.
The MMP has a pretty weak BEC in it so it may not be totally the servo's fault. I don't know why, I guess they thought it would be put in lighter 1/10 vehicles that didn't need lots of power for the servo. Guys who were putting the MMP in 1/8 buggies we're finding this out the hard way too, for a crawler type vehicle you definitely want an external BEC.
I'm pretty sure Castle's default voltage setting for their BECs (internal and external) is 5.1v to avoid blowing out any vintage 4.8v rated servos.
For as much as ESCs costs u would think since the ESC delivers the power to the servo that it would be able to deliver the power necessary to power a wide range of servos since in this hobby we tend to put the biggest baddest thing we can into or cars and put them in servo stressful situations.
The mamba max pro bec is only 3a though.
Another ? I have is that when I get the bec in how do I adjust it to 6v since I use a 2s lipo I don't want to fry the servo bcuz its max volt is 6v. Nominal is 4.8v but torque is only 222oz-in and I want the full 277oz-in
Castle bec's are adjusted using the Castle Link, no other way to adjust them that I know of. Your servo may say 4.8v or 6v, but in reality bofh are nominal voltages. A 4 cell receiver pack is 4.8v nominal but is over 4.8v when fully charged. A 5 cell receiver pack is 6v nominal but over 6 volts fully charged. Servo manufacturers use these nominal voltages for their torque ratings because they are common voltages used in rc.
Not sure where you heard Spektrum is Savox but Spektrum was developed by JR. The first Spektrum radios just JR transmitters in grey and converted to 2.4ghz. They even came with JR servos that were grey instead of black. I bring this up because I setup the BEC in my nephews LST for 6.2v and the old JR590's have been fine for years. Believe it or not the extra .2v made a difference, at 6.0v the led's on his truck would dim ever so slightly when turning. Set to 6.2v and no dimming at all.
I read it on rctech I think that its the same as savox, I was trying to find the tooth for the spline and that's where I read that spektr was savox.
I've heard good things about Jr though.
My programming card came with a USB cable and I emailed castle about these questions also and so far yalls answers and theirs r consistent ( not that I doubted u guys I just know that u guys r faster to reply then castle) and I also asked them what the USB was for and they said I can plug it into my computer like castle link. So that's cool.
Well im going to say Savox has nothing to do with Spektrum or JR. Spektrum and JR are owned or at least distributed pretty much exclusively by Horizon Hobby. Savox is not on Horizon Hobby at all so I doubt they have anything to do with Spektrum or JR. Spektrum servos are JR, they used to have almost the same numbers, a JR275 was a S275. JR does make some nice servos, I used to use their 9000 series until I became a fan of Hitec.
