Redcat volcano epx full throttle question
Hi,
I have been running a redcat volcano on lipos and at first when I bought it would pretty much do wheelies at full throttle on pavement. Now it kind of sputters at first and seems to always pull really hard to the right at first full throttle and then after I straighten it out it seems to run true. Any thoughts what may have changed? All I have changed is added aluminum steering knuckles to the front after I kept stripping them out.
U could have accidently thrown the alignment off.
Make sire everything is tight also check ur drive shafts make sure ur not missing one
If its sputtering on take off and u haven't changed gearing ur motor or ESC could be going out.
Have u tried putting a different battery in it? Maybe and more likely ur battery has lost its punch. If u can borrow one from a friend then try and see if that fixes it.
