Traxxas rustler running slow
Hi,
I have a traxxas rustler and it is going very slow. I've upgraded the original xl-5 system to a yellowrc 3250 brushless system. I am wondering what could be wrong with my rc. I have my rustler for 2 years now. As charger I use a Vector AC/DC nx85 fast charger from fusion. I also use the original NiMh battery packs. Also the rc runs fast in the first 10 seconds. After 10 secs it goes slow. When I drive my rc on slow for 5 min and I turn it off and than back on it goes the speed that it is supposed to.
Hopefully somebody can help me.
Welcome to RCU.
I would make sure to start from scratch when upgrading/installing a new ESC/motor combo. Set all your radio trims/settings to the center positions, and reset ESC throttle range calibration with the transmitter.
Using them NiMh batteries with your ESC's LVC turned on (for LiPo use) will also give results like you are describing. Turn off the LVC when using NiMh packs. Find a manual for your brand of ESC, as the picture below is only posted to show what the manual, flow of operations, may look like to turn off the LVC on your brand.
The programming card only makes it easier to see what values are being changed, but is not necessary to change parameters on the ESC. If you don't have the card, you have to use the "set" button to enter programming mode, and listen for beeps/watch LED light when changing parameters for basic items on the ESC.
That YellowRC brand looks like a re-branded HobbyWing type product and is why I posted pictures from that manual.
*updated* I do believe now, after looking at YellowRC manual, a person does need a program card to adjust the items on the ESC...bummer.
Reset All Items To Default Values (this is for HobbyWing EZRun ESCs...check with your manual for similar function)
At any time when the throttle is located in neutral zone (except in the throttle calibration or parameters program process), hold the “SET” key for over 3 seconds, the red LED and green LED will flash at the same time , which means each programmable item has be reset to its default value.
The problem with resetting the ESC to the default values is the Low Voltage Cut-Off will normally be turned on @ 3 volts per cell (LiPo battery pack use), and you will want the Low Voltage Cut-Off turned off when using NiMh battery packs.
http://www.yellowrc.com/support/manuals/
The LVC is item 1 on your ESC and the manual says to turn off when using NiMh packs.
I don't see anywhere in the YellowRC manual about programming card is "a must" to change parameters.
If you don't feel comfortable trying to get into programming mode using the "set" button method used on HobbyWing EZRun ESCs, you will need the programming card to change the parameters on the YellowRC ESC... as I don't see in-depth instructions on how to change item's values without the programming card.
Well then...That's what I was afraid of. I guess the purchase of the programming card is in order .
But I am almost certain turning off the Low Voltage Cut-Off will cure your problem.
OK thank you very much for helling
I have 2 batteries. One that has 3000mah and one that had 4600mah. When i run the 3000mah battery the rc does not run fast in the beginning.
In general, I don't think NiMh packs are good to use with brushless systems of any size. When my buddy and I first changed over to brushless, we still had our NiMh packs, so we used them. They didn't last very long. The brushless system tries to pull so much current from the batteries that they get really hot, enough to MELT the plastic shrink wrap on the pack. In all things electronic, heat is bad. Pretty soon, those packs wouldn't hold a charge anymore, they were toast. Lipo is the only way to go.
Lipos are not dangerous, I'll just put it that way. They can be dangerous if used in the wrong way, but it's rather hard to use them the wrong way unless you're purposely trying to do so. You need a decent charger that charges lipos. What charger do you have? Lipo will be $100-125 depending on what charger/battery combo you go with.
Moderator
LiPOs are less dangerous than NiMH. I have had a few NiMH and NiCD explosions/shorts. Typically, all chargers today that are not included with the kit are LiPO ready. You can tell us by seeing if there is a set of white plugs on the front or sides. If so, you have a LiPO charger. If not, you need one.
Battery; http://www.atomikrc.com/collections/...-with-uni-plug
Charger; http://www.atomikrc.com/collections/...attery-charger
I have this charger http://www.modelsport.co.uk/fusion-v...products/37637
On a very low budget? Try looking for the ever popular iMax B6AC charger. They come in 50 watt and 80 watt "flavors" as well as many re-branded versions (I use two of them, and the links are in US$ ...sorry.) . I don't know what type of battery connector you use, as some chargers come with the old Tamiya "white-ish molex" ones, and should be changed to something that can handle more energy flow like Dean style t-plugs or TRX connectors for an example.
On a very low budget? Try looking for the ever popular iMax B6AC charger. They come in 50 watt and 80 watt "flavors" as well as many re brander versions (I use two of them, and the links are in US$ ...sorry.). I don't know what type of battery connector you use, as some chargers come with the old Tamiya "white-ish molex" ones, and should be changed to something that can handle more energy flow like Dean style t-plugs or TRX connectors for an example.
The 80W can handle more such as bigger batteries and faster charging. I'd get the 80W myself. From the looks of the listing, it doesn't look like that charger comes with TRX adapter. So all you'll have to do is either solder a TRX connector to one of the adapters that it comes with or you can buy this adapter to plug into the Tamiya Molex adapter that the charger has. Buying the adapter is easier and will plug right together, but if you can solder it's whichever setup your prefer.
Tamiya to TRX adapter - http://www.ebay.com/itm/1-TRAXXAS-TR...item5899bee506
