New to rc racing looking for help with Rc10B4.2
I just got an Associated Rc10B4.2 buggy for racing. Im new to rc racing Ihave been to my local track a few times and most of them run a traxxas bandit 2wd brushless. But I have read alot on th Rc10B4.2 and I think it will be competitive with there buggys. I just need help picking a battery and charger . At the track I can run a 2s lipo or 6cell NiMH. I was thinking a SPC 2s 5000mah lipo. I have just never used lipo I hear that they make the car run faster then NiMH batterys. Any advice for a newbie would be appreciated. Thank you
The track I will be racing on is a clay oval track but they also have a SCT track with a few small jumps I want to run it on but most of the time it will be on the oval track. The buggy will have a late model dirt oval body.
Moderator
Oh. You're doing oval racing. Gotcha. Knowing that, you probably want a high MAH battery with a lower C rating.
Charger; http://www.atomikrc.com/collections/...attery-charger
Battery; http://www.atomikrc.com/collections/...-with-uni-plug
I'm curious , why would the battery make a difference since the Lipo is gonna give better power? I'm getting more and more into oval was just wondering why the suggestion of MAH.
Moderator
Well, higher MAH=longer run times. When you're running on an oval course, you are nearly on the throttle the whole time. Each one of these races last between 5-10 minutes, so you want a powerful battery, but not one that is too powerful, as it will disperse its energy faster and you won't have enough power to finish the race.
...I was thinking a SPC 2s 5000mah lipo. I have just never used lipo I hear that they make the car run faster then NiMH batterys. Any advice for a newbie would be appreciated. Thank you
In Layman's terms...a 2S LiPo battery is same as a 7cell NiMh battery in terms of voltage. LiPo batteries are also lighter than NiMh or NiCd batteries from back in the day.
