I stripped a screw, what do I do?
Moderator
Drill out the screw. If that doesn't work, get a cheap hex key that you have 2 of or something, place it in the socket at a right angle, and fill the hex with solder. Let it cool and then try to twist it out.
I'm going to try soldering or use super glue. The screws are in extremely tight, I have a bruise on my hand from trying to break the thread lock. I decided to grab the hex driver with vise grips and twist and that stripped the screw. Thanks for the help everyone!
