Yeti issues
Yeti issues
I bought the 1/10 scale Yeti about 3 weeks ago and was super pumped to get it home and try it out.. On the second run with it, I bent the drivers side rear drive shaft just from running on dirt roads, no jumping or bashing at all as I was still trying to get used to it.. So I did some reading and upgraded the whole suspension and the beefed up the rear axle housing with everything from Vanquish.. Wheels too.. Came out looking amazing, I was really pleased with the look.. Since the upgrades, I haven't been able to get through a battery pack with something breaking again.. The past 4 runs, Ive bent 3 more axle shafts and the Currie Antirock sway bar falls apart every time.. The stock sway bar obviously has to go back on unfortunately.. I'm extremely frustrated at this point as I cant find any better quality axle shafts and not sure what to do to fix these issues.. At this point, me and my daughter just run her Rukus and leave the yeti at home..
I literally had to pick up my lower jaw after reading your post. Running into all those hiccups...I feel bad for you. I went easy on the Yeti for the first couple of packs, 'cause my kit build felt a little tight in the gear department, and I wanted to ease into letting the solid axle rock racer rip through the backyard at full throttle. I don't remember reading about anyone having a gear mesh issue, but I felt better after allowing the gears to get to know one another for awhile.
There isn't too many Yeti owners here in RCU. I would check out RCCrawler for the best chance to possibly get answers. Or check out the crawler section here on RCU since the AR60 axle is used in other models. That's crazy about all those axles bending. I'm still getting used to the whole excessive body roll thing combined with the solid axle style of driving.
DMachine, is your Yeti the kit or RTR version? I don't know if Beef Tubes would help in your situation or not. I want to give you a simple answer, and I don't know of any "bad batches" of axles out there in the Axial world.
I own a yeti. I run castle 8th with 1/8 scale 2200kv motor on 3s. I have not bent anything. I have just shripped out the rear main driveshaft. The shaft going from tranny to the rear diff. I have not really been jumping just playing in the rocks in my creek. Besides that driveshaft I have not had any other issues. Though i do have upgraded aluminum steering assembly and front axle carriers.
Just replaced. I was told that when you upgrade the shaft, you will start stripping the rear diff. And the driveshaft is alot easier to replace. But im getting fed up. So the upgrade maybe in the near future.
