Problem with new Sumo
I recently bought a new Sumo 1/24 scale rock crawler and can't get it to turn on. I can' find an on switch on the vehicle, and the radio doesn't have a way to turn on the car on. Any help would be appreciated.
Does it turn on when you plug the battery in? Is there a button that you are supposed to hold in? If you bought it new, isn't there a manual? If there is, did you read it?
You bought it NEW? Not from eBay? If so, it should be stock. The manual is available online. The ESC and Receiver are "integrated" into one unit, and the manual shows the unit has an on/off switch mounted next to it. If you can't find the switch, put it back in the box, take it back to the store, and get your money back. You need a different hobby.
