Exceed rc buggy forza car
Hello. I just got a Froza buggy gas car for myself but I don't know what kind of nitro fuel I can use for this car. There are 20% and 30% nitro fuel and I don't know what's the different and which one I should use. Plus online I also saw Diff gear oil, Shock oil and After run oil, can someone please tell what are these oil and what do they do.
Thank you.
Thank you.
hi charger1 well you pickup a nitro buggy you have to break it motor gently , you can use 20%
or 25% use 30% for racing after motor broke in , differential oil has different weights (viscosity )
for the front , center , rear diff, i use 7000 front , 7000 center ,5000 wt in rear its how you want the buggy or truck to react going in turns , or out of turns ,shock oil weight is how you want the chassis to be stiff or soft i use 50wt in front , 40 wt in rear set up for going over jumps on race
track ,after run oil to coat piston ,sleeve and carb, nitro fuel is caustic to alumium over a long time , best fuel ,byrons , odonnell, S&W, blue thunder jeez hope i helped
