Rustler - Aluminum hop up Recipe
Hey all,
So I broke the stock springs on this truck after landing a pretty small jump. I'm looking to replace with better springs and hopefully upgrade some other plastic parts. I attached some pictures but the entire suspension is stock.
I've heard so much about how you need to have a healthy amount of plastic on an off road truck. I normally run this on a dirt track with a few small jumps. Can you recommend which parts I should upgrade to handle these jumps a little better, including your favorite springs? As you could see, I also race my cousins on road which is why I installed a wheelie bar so I'm interested in keeping some plastic so it's not too heavy. If you have links to the parts you recommend please post so I could buy right from your link.
I bought the Proline Powerstroke for my Firestorm. They are originally for the Slash, but they fit perfectly. they might work on the Rustler.
Rear: http://www3.towerhobbies.com/cgi-bin...&I=LXYWT9&P=ML
Front: http://www3.towerhobbies.com/cgi-bin...&I=LXYWT8&P=ML
Mounting Hardware: http://www3.towerhobbies.com/cgi-bin...?&I=LXALBZ&P=M
Hope they work for your application because they are worth every penny.
PS: i filled them with 35W shock oil and they perform well.
Good optional Aluminum Upgrades:
Front Shock Tower - http://www3.towerhobbies.com/cgi-bin...?&I=LXCSFM&P=7
Rear Shock Tower - http://www3.towerhobbies.com/cgi-bin...?&I=LXCSGT&P=7
Caster Blocks - http://www3.towerhobbies.com/cgi-bin...?&I=LXCSFZ&P=7
Knuckles - http://www3.towerhobbies.com/cgi-bin...?&I=LXCSGD&P=7
Rear Hub - http://www3.towerhobbies.com/cgi-bin...?&I=LXCSGW&P=7
Turnbuckles/Camber - http://www3.towerhobbies.com/cgi-bin...&I=LXPNL2&P=ML
Bellcrank - http://www3.towerhobbies.com/cgi-bin...&I=LXTKH5&P=ML
On the springs, try these:
Orange 2.5" x 2.9lb - http://www.amainhobbies.com/rc-cars-...osa5154/p15720
Silver 2.5" x 3.4lb - http://www.amainhobbies.com/rc-cars-...osa5156/p15233
