Almost bulletproof!
Almost bulletproof!
After upgrading just about everything on my Emaxx 3908. I think it can be considered bulletproof. But, the only part I haven't been able to find a raplacement for is the transmission. I can find an aluminum case for it. But, can't find steel gears to put in it. I only see steel gears for the 3906 on Ebay.
Most of the guys that get the aluminum cases are trying to get rid of some heat without re-gearing like they should or they just like it cuz its pretty (which it is lol). unless you can get your hands on some titanium gears (which i'm pretty sure don't exist, and if they do would cost an arm and a leg) then steel is the best bet.
I'm not sure what the trans gears are made of in the 3903/5/8 Maxx that's why I just referred to them as metal. They are likely a sintered steel similar to the diff gears though. As I said the stock gears are basically bulletproof, no reason to upgrade so nobody makes any gears (in any material) that I've seen. Besides when most people want to do something with the trans it's usually to replace it with a 1/8 style center diff to put the motor lower in the chassis. The 2spd gears are a different story, they're plastic as are the shifting parts. There are aluminum upgrades for the shifting parts but I'm pretty there aren't any upgrades for the plastic gears and they apparantly survive quite a bit of brushless abuse as long as you don't shift while on the throttle.
Maybe not for the emaxx but others have a one piece trans and motor plate like the 2wd slash. In those instances the heat can be reduced slightly but i don't find it to be worth it and yes it adds some weight. Keep calm, i'm not interested in an argument about something so silly.
Why are you telling me to keep calm? It may be a silly subject but what about that post, with the well reasoned "arguments" wasn't calm? Maybe it's not liberal stoner hippy Koombaya around a campfire calm but jeez, turn down your sensitivity meter.
Edit: Nevemind. No longer interested.
